Is 2014 model 308 taken?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
08.05.2020 20:36 # 1
cimariva
The pejo love inside me is endless. I found the exact case I was looking for and the color I wanted 308. I would be glad if those who share information about this tool. My questions are these. How is the handling? How about a 1090 kg vehicle at high speed on the long road?
Is it a problematic vehicle in general? Is the touch screen problematic? Is the following vehicle worth buying
http://www.sahibinden.com/ilan/vasita-otomobil-peugeot-pasahan-auto-dan-dizel-308-emsalsiz-kirmizi-kazasiz-475646123/detay
08.05.2020 20:36 # 2
onlycihan
The vehicle looks beautiful, what stands in the trunk is the sound amp, it is likely that the screen has been dismantled and some connections have been taken from the back.
long road short road does not matter, I think it is a quality vehicle that can be used in every shape.
I think that some deck converters were converting the sound on the direct speaker cables to the signal, maybe it was possible to receive a sound signal from the rear doors without touching the screen at all, but if you take a speaker in a pandizot that doesn't count, you can get it removed.
the onlycih 2017-10-14 18:24:02
08.05.2020 20:36 # 3
ggitaristt
It can not be 1090 kg or 1500kg even with old case diesel automatic hb 308 ..
Also, I was tortured from this car .. At the age of 3 has not been examined yet .. If the km has been reduced, it is incomprehensible .. I say ...
08.05.2020 20:36 # 4
onlycihan
Yes, it is not understood in the records, but if it is connected to a computer, the km will be certain.
08.05.2020 20:36 # 5
uzunca961
Teacher km is not understood by computer, unfortunately, what is on the display. If the maintenance has been done in the service, the km information is learned from there and you can look at the maintenance miles, there is no other way.
08.05.2020 20:36 # 6
cimariva
I had never looked at the Km event from that point of view. No exams can be deleted from the brain and the key. I do not know how accurate the weight is 1090 kg in the technical specifications section.
08.05.2020 20:36 # 7
uzunca961
[QUOTE = cimariva] I have never looked at the Km event from that point of view. No exams can be deleted from the brain and the key. I do not know how accurate the weight is 1090 kg in the technical part. [/ QUOTE]
It may be that he chose the wrong tool or S.com wrote it incorrectly.
08.05.2020 20:36 # 8
cimariva
[QUOTE = uzunca961] [QUOTE = cimariva] I had never looked at the Km event from that point of view. No exams can be deleted from the brain and the key. I do not know how accurate the weight is 1090 kg in the technical part. [/ QUOTE]
It may be that he chose the wrong tool or S.com wrote it incorrectly, no need to hang out [/ QUOTE]
I am skeptical about how the cause of losing weight will affect handling. It writes the same kg in different places.
https://www.auto-data.net/tr/?f=showcar&car_id=19214
08.05.2020 20:36 # 9
ggitaristt
It says probably 1200 kg to 110 diesel .. 1095 kg is yours .. I think the handling is nice but it feels very bad on the rough road because hard suspension ..
08.05.2020 20:36 # 10
KILIC
I think it is taken. However, it was very light, but even my 207 is 1281 kilos :)
08.05.2020 20:36 # 11
ilkeraygun
I bought on 11.12.2017, Peugeot 308 1.2 active, 83 ps, 2014 model, 16.000 km, red, no changing or painting, I found a very clean vehicle and I could not bear it, the last 55 thousand TL by bargaining over 57 thousand TL. I was able to download and bought it, it is very aesthetic in design, touch screen is very useful, I write my impressions as I use it in the coming days.
08.05.2020 20:36 # 12
[QUOTE = ilkeraygun] I bought on 11.12.2017, Peugeot 308 1.2 active, 83 ps, 2014 model, 16.000 km, red, no change or paint, I found a very clean vehicle and could not bear it, the bargain over 57 thousand TL I was able to download it for 55 thousand TL and bought it, it is very aesthetic in design, touch screen is very useful, I write my impressions as I use it in the coming days.
First of all, welcome to us. May your vehicle be beneficial my teacher, Allah
08.05.2020 20:36 # 13
ilkeraygun
Amen, thank you.
