Irregular operation of the vehicle with LPG in gasoline?
08.05.2020 17:49 # 1
hakan38
friends vehicle lpg was like a clock but it works by singing on the petrol. Exhaust blows as if stopping to stop idle in the form of idle, this is what is going on at high speed, there are chills from the second-second traction. anybody have an idea?
08.05.2020 17:49 # 2
impact
it is caused by the trouble in the gas pump.
vectrada had the same problem hose at the pump outlet rotted and folded. we changed it, the problem is solved.
08.05.2020 17:49 # 3
hakan38
thank you my brother yaw motor only from the brain
08.05.2020 17:49 # 4
rolandgarros
maybe the vehicle is protesting after the last hike LOL you continue with lpg forget about gasoline Big smile
08.05.2020 17:49 # 5
hakan38
:) room is a possibility, but why don't you take me to the service, it seems to me that the protest is more heavy.
08.05.2020 17:49 # 6
rolandgarros
[QUOTE = hakan38] :) There is a possibility, but why don't you take me to the service, it seems to me that the protest is more heavy [/ QUOTE]
Do not neglect the joke of the job and when you buy gasoline, it is useful to use the vehicle in gasoline that day. Let's not forget where the vehicle came from Smile Continuous use of lpg can cause serious damage to the vehicle. Embarrassed
08.05.2020 17:49 # 7
Black GTI
I have been using gasoline for a month, after the time I filled the lpg tank, the car started after 10-20 km, the same problems started with the gas, shaking as I hit the gas, don't make a sound, the traction is already going, it seems like the car is blocking something. repeats because I did not delete the fault. I smelled my o2 sensor was broken or ignition coil. The problem is that the pug's brains have absolute problems for both lpg and gasoline events, whichever fuel it stores in the vehicle, and when it uses the other one, it has an absolute problem and unless it clears the memory from memory, it does not have the same failure. I researched it a lot and I see that many vehicles have changed O2 sensor ignition coil and even fuel pumps. but the pug 206 series is not working lpg friend ..: /
08.05.2020 17:49 # 8
hakan38
The essence of it is like that
08.05.2020 17:49 # 9
hakan38
Just as you said, the master said the o2 sensor is broken and even the catalyst is broken, they cost 1500 TL and came to mosmor home. I didn't know what the hell I would do
08.05.2020 17:49 # 10
kuscu38
My earth did not look at the petrol MAP with the gas pump, clean the throat butterfly
08.05.2020 17:49 # 11
hakan38
My brother, God sent you, brother, where are you taking the pilgrim? I have no fixed place.
08.05.2020 17:49 # 12
hakan38
What is the map of the enzyme?
08.05.2020 17:49 # 13
kuscu38
The gasoline map adjusts the idling of the vehicle, it can do without ignition by looking at the spark plugs, it may be a problem with the throat butterfly.
BAĞCILAR GÜNGÖREN INDUSTRIAL SITE 23. BLOK ERCİYES OTO 2 HALIL AND MUHAREEM MASTERS IN MASTER WORKS. THEY HELP.
08.05.2020 17:49 # 14
hakan38
oh brother ist. I'm not bored of it, I'm in Kayseri or I can go to the island, it's hard
