iron sounds at idle
08.05.2020 17:14 # 1
bjkamil
My problem with friends is the engine runs noisy when the vehicle is at 1000 rpm. When the vehicle is at 1,000 rpm, there is a mixed shake in the iron noise. When I get out of the vehicle and look at the exhaust, there are popping noises. No problem under 1000 cycles and above. a friend said that he was from the valve setting. Has this happened to her?
08.05.2020 17:14 # 2
Serkan
It is QUICK.
If Mechanical Noises are coming from your Engine;
• Piston pin sound
• Circlip sound
Pis Piston sound
• Piston arm sound
• Arm bearing sound
• Main bearing sound
• Crankshaft noise
• Valve sound
08.05.2020 17:14 # 3
bjkamil
Friends problem solved. exhaust last muffler replaced. sound cut off. "Wink"
