intermediate gear in autos
08.05.2020 15:38 # 1
ramtas
friends, do you know how these automatic transmissions make intermediate gears, how does the transmission make the feeling of having a half-shifted gap between now? it does not do more in the summer. selenoids oil changed last year. but the problem continues. when the car runs irregularly it disappears in the intermediate gears. so there is a shift between 2 and 3 when it is gone, it disappears. so our problem is like whatever makes the intermediate gear ...
08.05.2020 15:38 # 2
metin
yes it makes very sense.
When I changed the solenoids, I did not understand that the intermediate gears disappeared as well, while the vehicle was moving, the gear shifts were up to 3400-3500 revolutions. Right now, thank God there is no problem, I feel the intermediate viruses, the traction of the vehicle has improved, it is not normal for you to go 90 with 3000 rpm, but under normal conditions, it should go with 90 rpm with 2500 rpm. Well, when you go 90 at 3000 rpm, when you pull your foot out of the gas, does it decrease to 2500 rpm?
08.05.2020 15:38 # 3
ramtas
When I pull my feet out of the gas, it is as if I gave the gas when I was in the car and it goes down to minimum speeds as if the car is not in gear.
08.05.2020 15:38 # 4
ramtas
But when my car goes to 90 la at 3000 rpm, if I make a bottom gas, I take 3 to 4 again and make 3000 rpm 110. As if 3000 rpm is going 90, it goes like 3 or 4 gears, it doesn't go to 4.
08.05.2020 15:38 # 5
This automatic transmission event is slightly variable ... The same situation may not be observed in every vehicle.
08.05.2020 15:38 # 6
metin
[QUOTE = CeCoLi] This automatic transmission event is slightly variable ... The same situation may not be observed in every vehicle. [/ QUOTE]
yes cem brother is variable but it changes between 100-105-110 according to 3000 cycles. but 2500 cycles are the healthiest when going to 90 la.
08.05.2020 15:38 # 7
alisuat
Let me give you a very simple example yesterday, when I was testing my new solenoids yesterday, when the car was 3 at 90, I suddenly threw the gas up to 4000 rpm and then increased to 5000 rpm as if it shifted one more gear.
There are 2.5 gears in our cars
08.05.2020 15:38 # 8
metin
yes intermediate gears are going 1 - 2 - 2.5 - 3 - 3.5 - 4.
08.05.2020 15:38 # 9
meandros
I agree exactly ...
When I press the throttle normally, my vehicle shifts a gear at 2500 but there are intermediate gears.
I wish it would be super if it had been censored with 5. I made a 190 more gear in my car istio melet :)
08.05.2020 15:38 # 10
ramtas
In my problem, I think that it should stay in intermediate gear. no other signs of malfunction. no malfunction code in the computer.
08.05.2020 15:38 # 11
metin
meandros 5 would be the same though in the future I never used a manual 307, but I'm sure they are 5th gear 2500 revs 90 km / h.
The reason for this is that the speed limit is 90 beforehand and they have adjusted the minimum value of the vehicle to 90 km / h in order to keep the vehicle users at this level.
08.05.2020 15:38 # 12
ramtas
I just went from the blowing to the spit. I went in the snow mode 7 8 km.
08.05.2020 15:38 # 13
metin
I did not know what is the logic I said in my master.
08.05.2020 15:38 # 14
48gs306
my friend you will feel the 306 manual gear of my car you will put it in the breaker believe this is another air. i think sell the same gear of the same car Thumbs Up
08.05.2020 15:38 # 15
berk2309
We have 48gs per triptonic manuele, you can feel the power cut: D we are comfortable we: D
08.05.2020 15:38 # 16
metin
[QUOTE = 48gs306] my friend you will feel the 306 manual gear of my car you will put it in the breaker believe this is another air. I think sell the manual gear of the same car Thumbs Up [/ QUOTE]
I also agreed with you, I would say I would drop gears, I would not be in autism, I would not ride in life. My advice to you is that you will not take over a thousand automatic peugeots once again.
When he goes on at 4, he gets 3 to 2 if he does not get from 4 to 3, he digs a thousand to a cutter.
Likewise, if you take off the heels, you will be in sports mode directly, while it needs to change gears at 3000 rpm, it goes up to 6000 rpm and changes it to millennium by millimeter. On the best part, you do this by playing with the clutch with the gears before I even take my hand (:
