Interior lighting aid
08.05.2020 21:08 # 1
Cemm
Hi guys, I went to the industry on Saturday for my interior lighting and general maintenance. 1.6 XS 307 2004 When the automatic doors are opened, my lights are not lit, the front is lit when the left button is pressed, the back is pressed when the button is pressed, the front center is not lit at all. I kept it pressed for 5-10 seconds while at the station, there is no change.
Note: Can you help with battery prices? To give an idea, the subject of automatic transmission was quite a problem, the brake sensor has changed, the oil has changed, but there is no solution. those who have experienced this problem have told me that the gearbox is heating up very quickly and my vehicle does not cause problems when the engine temperature is 85-90. ConfusedConfused
I love my car, despite all the problems, maybe I will think of selling it after 3-5 years
Ahh, the bidet shows airbag error, I asked you for the price of the steering wheel on my screen, he told you a figure like 160
Jammu 2019-02-03 22:10:12
08.05.2020 21:08 # 2
GokhaN
A good electrician takes care of that problem, it's not a problem.
This year, the expensive 240 in batteries are around 210-220 in affordable ones. It's time to spend some money on the car Smile
08.05.2020 21:08 # 3
Cemm
Brother I have been making expenses since the day I bought the car.
08.05.2020 21:08 # 4
First of all, welcome to us. A good electrician takes care of the lamps, as the Gökhan knows about the peugot. As you said, airbag winding is being repaired, 160 TL is a nice price, but you have to be at the beginning, some people can say that I have resisted and did it. then it is necessary to pay attention that the airbag does not open. battery prices start from 200 TL on average and 400-500 TL. unfortunately, we have to find a good master who understands the gearbox. If you want, I can help with the master.
08.05.2020 21:08 # 5
Cemm
Goodbye brother, I have been reading for a long time. Smile I am not sure if the brother is already airbag. I applied a friend for the transmission again. At first, I use it at a high speed and it does not fail, but if I fall under 2-3.5, I am immediately protecting the solenoid valves.
08.05.2020 21:08 # 6
there is a lot of forgetting Smile brother no problem. The winding and steering pump are very different things bro. Unfortunately, you will need to have the steering pump repaired, and the price will be around 300-500 TL.
08.05.2020 21:08 # 7
Cemm
[QUOTE = sonerkyl] a lot of forgetting work Smile brother no problem. The winding and steering pump are very different things bro. Unfortunately, you will need to have the steering pump repaired, and the price will be around 300-500 TL. [/ QUOTE]
I said maybe Big smile
