Interior Ceiling Lamp Problem?
08.05.2020 17:15 # 1
ertugrulll
I looked at the site, I looked for only one topic opened, I opened a New Thread because the room is not about me. When I pressed the Switch in advance, my interior lighting lamp was on and slowly darkening. Or when I opened the doors, my interior light lamp was on. It doesn't burn either way right now. When the doors are opened, the road computer warns, whichever door is open, the picture appears, but the ceiling lamp does not light up. I went, bought a new set of ceiling lamps, installed them again, it is not lit again. It burns when I open it in my normal hand. But it doesn't work when I put it in door mode. & Nbsp;
What is the reason for this? Which insurance or insurances should I look at? What is the cure? & Nbsp;
08.05.2020 17:15 # 2
Alicilik
Sir, there is a problem with the key connected to the door sensors or the fuse has blown due to it ^ spearo ^ cenker brother looks gorurse
08.05.2020 17:15 # 3
mhakan71
If the ceiling lamp lights when it is pressed manually, the fuse is solid, press and hold the button for 15-20 seconds, try again & nbsp;
08.05.2020 17:15 # 4
ertugrulll
When I say button? My ceiling lamp is not buttoned, with 3 levels of tabs, door switches are not already in the door. When I said a button to my mind, only the key of the car came, I did not do it now from the window.
Another Button did not come to my mind. & Nbsp; div>
Thanks In Advance.
ertugrulll 2013-01-03 23:58:18
08.05.2020 17:15 # 5
_semihk_
[QUOTE = ertugrulll] When I say button? My ceiling lamp is not buttoned, with 3 levels of tabs, door switches are not already in the door. When I said a button to my mind, only the key of the car came, I did not do it now from the window.
Thanks In Advance.
"Clap"
08.05.2020 17:15 # 6
mhakan71
Check fuse F22 (20A) on the fuse panel
08.05.2020 17:15 # 7
murat20021978
Hello, this happened to me. It lights up when it opens normally, not when it opens the doors. The fuses of the two are different (the fuse of the electricity coming when the doors are opened and the fuse of the electricity that comes directly in close proximity). Now I do not remember how many numbers, but I wrote in the forum before the insurance number. Nothing to be afraid of absolutely from insurance.
08.05.2020 17:15 # 8
ertugrulll
[QUOTE = mhakan71] Check fuse F22 (20A) on the fuse panel [/ QUOTE]
I take a picture of my fuse box and send it. If F22 is a yellow fuse, I disassembled it, plugged it in and replaced it, it didn't burn again.
Is there any other insurance?
08.05.2020 17:15 # 9
hasanekiz
hi let me try to help you a little if the ceiling lamp has short circuit & nbsp; bsi has cut off the electricity. close the car's doors open the left front door open and close the ignition Pull the selector lever and the wiper arm at the same time and wait 3 seconds, the horn will sound and be active. but check the ceiling lamp line first, do not short circuit
08.05.2020 17:15 # 10
rzsrht
[QUOTE = hasanekiz] hello let me try to help you a little if the ceiling lamp has a short circuit & nbsp; bsi has cut off the electricity. close the car's doors open the left front door open and close the ignition Pull the selector lever and the wiper arm at the same time and wait 3 seconds, the horn will sound and be active. But first check the ceiling lamp line, no short circuits [/ QUOTE]
Dear God, bless you. I had the same problem. I did what he said right now. the lights come on when I open the doors and my car is locked. & nbsp;
08.05.2020 17:15 # 11
night_blue_2229
[QUOTE = rzsrht] [QUOTE = hasanight] hello let me try to help you a bit if the ceiling lamp has a short circuit bsi has cut off the electricity. close the car's doors open the left front door open and close the ignition Pull the selector lever and the wiper arm at the same time and wait 3 seconds, the horn will sound and be active. But first check the ceiling lamp line, don't short circuit [/ QUOTE]
I had the same problem. I did what he said right now. The lamps come on when I open the doors and when my car is locked.
[/ QUOTE] brother is burning closely with the normal hand, but should I try what he said?
08.05.2020 17:15 # 12
fatih206+
hello same problem in me, the interior lamp does not light up when the existing doors are hurt in my arc & nbsp; but i can manually switch it up when you get rid of the recipe, but the lamp goes through the doors again, what can be the reason for this, can you help me please
08.05.2020 17:15 # 13
can926
Hello friends
I saw that the ceiling lamp of my car did not light up today, when I opened it to the ignition, it was manually illuminated by the ceiling lamp, but when I locked the doors, slowly extinguished and when it hurts, there was no incident, I applied what was written as much as I could examine. But the result was not positive. What should I do? My car is 2001 model 1.6 xt model.
Thanks for the answers now can926 2015-03-16 00:10:24
08.05.2020 17:15 # 14
can926
Isn't there a friend who can help the problem?
08.05.2020 17:15 # 15
bekir can
you turn the ignition half a turn (the first level from the working position) you hold the ignition button of the top lamp for 10-15 seconds, then you turn off the ignition and the event freezes back to normal.
08.05.2020 17:15 # 16
Vefa
Hello arkads 2007 206 there is a similar problem in me, my ceiling lamp is lit when the door is opened, it does not light when I want to burn it.
08.05.2020 17:15 # 17
erherg
I have 2009 model 207. After replacing the interior roof lamps, I guess it was short-circuited when I could not take my speed and change the torpedo light, and the torpedo light did not burn. What could be the problem?
08.05.2020 17:15 # 18
SIVASLI
friends & nbsp; Since I bought my pejo 307 xt, the interior lighting lamp was not lit up to this day. I did it, thank you
08.05.2020 17:15 # 19
SIVASLI
If the ceiling lamp is on when it presses manually, the fuse is solid, hold the button for 15-20 seconds, try again
08.05.2020 17:15 # 20
Kemal2072
Thank you very much, I had the same problem. I applied this application & nbsp;
and it works fine now.
Page : / 2
