Intake Manifold Air Temperature Sensor Hk.
09.07.2020 10:17 # 1
arifbsrn
Hello guys.As you know from the topic I opened before, I have problems such as idling fluctuation and falling from traction in the vehicle. Yesterday, while checking the sensors, I saw that the sensor (number 7) under the throat flap, which I added below, did not have 2 nails (total 4 nails - two nails left side by side. , the other two are broken.) I did some research on the internet, but I could not find out exactly what problems this sensor caused by the malfunction or not fit. The code of the part is listed as 1920 1J on partsouq.com and you can reach it by clicking here on the link of the part. Thanks in advance for your valuable comments. arifbsrn2020-07-09 10:18:06
09.07.2020 21:38 # 2
If it gets air from there, it may cause a malfunction of idle, sir.
10.07.2020 11:59 # 3
kaan206
1-oxygen sensor 2-throat test 3-idler motor Try cleaning them with a lining spray
10.07.2020 12:08 # 4
ismailkaya
Is your vehicle 1.4 75 like? 90's?
10.07.2020 15:34 # 5
arifbsrn
Let me try to fix it with plastic clamp, hocam.birde need to check its strength with a voltmeter actually [QUOTE = sonerkyl] if it gets air from there, it may cause a breakdown of idle, sir. [/ QUOTE] I had cleaned the oxygen sensor and the idle motor with a lining spray as you said recently. I had the throat throttle cleaned a few times ago, sir [QUOTE = kaan206] 1-oxygen sensor2-throat test3-idler motor Try to clean them with a lining spray [/ QUOTE] 75` lik [QUOTE = ismailkaya] Is your vehicle 1.4 75? 90's? [/ QUOTE]
