Instrument Panel Lights
08.05.2020 20:54 # 1
kayaca
206 Is it easy to change the lights on the instrument cluster? I want to make turquoise or green can also be blue
08.05.2020 20:54 # 2
onlycihan
I think the most beautiful numbers are the red speed bars are red.It looks better and does not look at night.
08.05.2020 20:54 # 3
light bulbs do not end my brother, there is an orange film in the place that writes km and rev speed, it needs to be scraped or changed.
08.05.2020 20:54 # 4
kayaca
this is probably something to do
08.05.2020 20:54 # 5
Brother, it is a bit troublesome, obviously it is easy if it is just a light bulb, but it has to be scraped because the dial is orange. There would be detailed topics in the forum.
08.05.2020 20:54 # 6
Gokcesel
Actually, if you have a hand, you will be able to handle a few hours. As Soner brother said, if you scratch the ground behind the dial and draw the foil in what color you want, you will get the image you want.
