instant misfire
08.05.2020 18:34 # 1
mehmetselvi_58
Friends mrb, first of all, good candles
I just joined the form
I am a user of 206hdi filini
I have such trouble, run the car in the morning and get four
When I stop at the traffic or the lights after the mileage, my vehicle is fixed for a second time as hur hur, but when you make the bottom gas to the car, it cuts off at two cycles and throws smoke of course.
Help please
No note when cold, when the vehicle is fully hot, there is no heat. mehmetselvi_58 2014-05-25 20:34:30
08.05.2020 18:34 # 2
mehmetselvi_58
Bid they say this can be a maf sensor
08.05.2020 18:34 # 3
mehmetselvi_58
Don't you have friends to help?
08.05.2020 18:34 # 4
mehmetselvi_58
Don't you have friends?
08.05.2020 18:34 # 5
mehmetselvi_58
I wonder if I'm wrong
Forgive if there is such a thing
08.05.2020 18:34 # 6
kuscu38
My teacher doesn't normally do it, but you said stop and get up. The first thing that comes to my mind is that the sensor is in a sudden stop when you stop, that is, only the sensor, the map, comes to my mind. I guess it may be a problem with the coils if he is doing it constantly or on the move except from him.
08.05.2020 18:34 # 7
kuscu38
Clean the throat butterfly, then have a look at the oxygen sensor. Replace the spark plug and spark plug wires as ignition. If it has been more than 1 year, I recommend you to replace it if nothing is too much. Besides, clean the air filter should be 5-10 liras bisheyt.
08.05.2020 18:34 # 8
mehmetselvi_58
Yes it feels when I stop, the mishap doesn't light up the malfunction lamp either
No, when it's cold, when it's hot
It happens when the heat is enough
Also my vehicle is diesel
08.05.2020 18:34 # 9
mehmetselvi_58
I still couldn't solve the problem
