Installing the Peugeot 301 Radio/Multimedia Handle
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
20.06.2021 21:00 # 1
mahmutr
Hello Friends, I told you about 301 Activeye Allure Tape Attachment. If you don't know, I'm leaving the link of the topic here:
"Brother I Have No Place To Attach Tape/Multimedia Handle!" I hear you say Smile Don't worry, they all have it.
Actually, there is room for all Peugeot 301 and above, but it is sold in Active or Access packages without being fitted. Today I will explain how to install it. It is both difficult to explain by writing and you may not understand it, so I will explain with photos.
There is no need for any coding after installing. Plug and play !
First of all, we remove the Steering Wheel Cover from the Screw Under the Steering Wheel.
After you remove it, you will see that there is such a valve. We are removing it. (It will come out as you shoot.)
A socket like this will appear before you. Here You Will Install 301 Radio/Multimedia Arms Sold On The Internet. Think Like USB, Push It In, It Will Go In And It Will Sit.
< /b>
Set Shape.
Before Closing the Cover Again You Need To Cut The Rail A Little Bit Or The Bottom Cover Won't Fit .
Don't See A Thank You Too Much :)
10.08.2022 13:07 # 2
mahmutr
+Up Still Updated !
