Installing fog lights in the active package
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008 (2020-)
22.12.2023 22:59 # 1
Shark26tr
Hello, my vehicle did not have fog lights because it was the most empty package. I wanted to install fog lights because I constantly travel in an area with heavy fog and rain. The service said it would void the warranty of the vehicle and they said no. Then I bought the parts from the internet and took it to the service, they said it would damage the brain and cause malfunctions and they still did not install it. Lastly, they said let's install it manually by installing a button inside and taking direct current from the battery, they wanted 6000 TL labor, they wanted 6000 TL labor, so a friend and I did the installation ourselves, cost and required parts1-) Peugeot 2008 (2020-2023) Cornering Guidance Front Left Fog Lamp right left set 2350 + 2350 TL part no: 98313038802-) Peugeot 2008 (2020-2023) Front Bumper Fog Light Frame set right left 2100 TL3-) Peugeot 2008 (2020-2023) Fog Light Connection Set part no: 1681127380 2300 TL4-) TES-SANSOKET H11-FOG INSTALLATION 275 TL + relay 45 TL (I bought it from the uğurböcekli shopping site) first, we removed the covers from the old fog light location. We disassembled the interior from the rear and passed the prepared electrical wiring from the inside and passed the + - and on/off cable section to be connected next to the headlight to the fuse/battery area. The fog light location in the bumper is already ready. I secured the mounting legs with 3 screws. Then, I installed the fog lights with 3 screws. We replaced the covers. I secured the existing connection cables to the battery to the positive and negative terminals with a small number 10 nut and screw. I connected the cable end where the on/off button will be connected to the + leg of relay number 16 in the fuse box next to the battery. There are 3 legs. If you connect it incorrectly, it does not cause an error, but the front fog lights do not come on, only the rear ones work. No problem. We identified the correct leg, wrapped the cable around the bottom and replaced the relay. We turn the part on the headlight on/off lever located to the left of the steering wheel that turns by turning and turns the rear fog lights, and when I turn the rear fog lights on, my front fog lights also come on :D I've been using it for 1 week and no error codes or malfunction lights have come on. The front fog lights already get electricity directly from the battery. Only when you turn on the rear fog lights, the electricity coming to the line opens the relay connected to the fog light cable, and the front fog lights are activated. Cornering lights etc. features do not work. It works directly in on off mode, which is enough for me. For any questions etc., you can reach me via DM on Instagram Shark26tr. https://resim.pro/i/NjMF1432https://resim.pro/i/2Gh11431https://resim.pro/i/rU6H1433https://resim.pro/i/smVr1430https://hizliresim.com/3h2u657https://hizliresim.com/3c1sbz4 Shark26tr2023-12-23 23:02:16
