installing a foggy bumper
08.05.2020 16:50 # 1
mehmet6667
mrb friends vehicle is 206 xr 2000 model, there is no fog light in my car, there is no fog in the bumper, if I buy a fog bumper, can I install a fog light, so I need a separate button to open the fog from the inside, I would be glad if you give information.
08.05.2020 16:50 # 2
monur
[QUOTE = mehmet6667] mrb friends car 206 xr 2000 model, without fog light in my car without fog, I can install fog lights if I buy a fog bumper, so I need a separate button to open the fog from inside, I would be glad if you give information. [/ QUOTE]
On the back side of the bumper, the fog lights are marked with bearings and where to cut. No need to re-bumper.
In addition, if you turn the part belonging to the fog light on the signal arm 2 times, and if the indicator light on the instrument panel 1 is green and the orange fog light is on, it has a system. If only the orange sign is lit in the first level, you will draw a separate line. >
08.05.2020 16:50 # 3
mehmet6667
[QUOTE = monur] [QUOTE = mehmet6667] mrb friends car 206 xr 2000 model, with no fog lights in my car, without fog, can I install fog lights in the bumper, I would like to have a separate button to open the fog from inside, I would be glad if you inform me. [/ QUOTE]
In addition, if you turn the part belonging to the fog light on the signal arm 2 times, and if the indicator light on the instrument panel 1 is green and the orange fog light is on, it has a system. If only the orange sign is lit in the first level, you will draw a separate line. > [/ QUOTE]
thank you brother, I will look and write from here ..
08.05.2020 16:50 # 4
206206
I & nbsp; I got fog & nbsp; front, control, rear fog & nbsp; cola & nbsp; I added . I did not draw a separate line.
08.05.2020 16:50 # 5
mehmet6667
[QUOTE = 206 206] me & nbsp; I got fog & nbsp; front, control, rear fog & nbsp; cola & nbsp; I added . I didn't draw a separate line, so [/ QUOTE]
how many fog is there in the back, is it not the only one, the red one below
08.05.2020 16:50 # 6
206206
yes one, here is the arm that tied the fog behind, master
08.05.2020 16:50 # 7
mehmet6667
[QUOTE = 206206] yes one, here is the arm that opened the fog behind the back master [/ QUOTE]
okay thanks ..
08.05.2020 16:50 # 8
mehmet6667
Look at this, if both are on, your indicator will describe where the installation cable is hidden. [/ QUOTE]
so there is no fog in the buffer to cut, I get it & nbsp; then fog lights
08.05.2020 16:50 # 9
206206
yes back to cut & nbsp; belli & nbsp; but
does not work properly & nbsp; master & nbsp; need, cuts with a utility knife & nbsp; o & nbsp; it is not symmetrical, i.e. & nbsp; certain & nbsp; is happening.
knows the job & nbsp; Master & nbsp;
206206 2012-06-06 10:49:44
08.05.2020 16:50 # 10
mehmet6667
[QUOTE = 206206] yes certain & nbsp; but
a proper bi & nbsp; master & nbsp; need, cuts with a utility knife & nbsp; o & nbsp; not symmetrical
knowing the job bi & nbsp; Master & nbsp;
okay, thank you bro, we would also buy a buffer, haybiye ..
08.05.2020 16:50 # 11
206206
getting to & nbsp; no need & nbsp; it doesn't end with buffering & nbsp; dye of & nbsp; montage all money, & nbsp; I & nbsp; last year & nbsp; Just got & nbsp; I got the fog first, & nbsp; then in industry & nbsp; property man & nbsp; a friend & nbsp; There was & nbsp; I got it installed.
08.05.2020 16:50 # 12
mehmet6667
[QUOTE = 206 206]
my car is white like yours, what brand did you get it
08.05.2020 16:50 # 13
206206
I bought the pair for $ 100 & nbsp; & nbsp; i don't know your brand
08.05.2020 16:50 # 14
mehmet6667
I bought the [QUOTE = 206206] couple for 100 liras & nbsp; & nbsp; I do not know the brand [/ QUOTE]
brother it says to my car, for 98 models, I do not know if there are 98 models 206 ..
http://urun.gittigidiyor.com/garaj/peugeot-206 -1998-white-cis-raw-right-left-team-57,318,225 Reviews
08.05.2020 16:50 # 15
206206
your headlights & nbsp; patterned old & nbsp; type,
the edges of the fog in the ad & nbsp; it seemed striped to me & nbsp; mine gloss flat glass & nbsp; as
206 & nbsp; & nbsp; first In 1998, & nbsp; output
08.05.2020 16:50 # 16
mehmet6667
[QUOTE = 206206]
your headlights & nbsp; patterned old & nbsp; tip,
yes, I am going to buy a patterned headlamps, namely an ice headlight but a lens headlight with lens headlight.
08.05.2020 16:50 # 17
206206
then & nbsp; beautiful & nbsp; would & nbsp; as a team
08.05.2020 16:50 # 18
mehmet6667
[QUOTE = 206206] then & nbsp; beautiful & nbsp; would & nbsp; as a team [/ QUOTE]
thank you, sunk fish goes to the side :)
08.05.2020 16:50 # 19
206206
o & nbsp; When & nbsp; will be & nbsp; also change the rear stops :)
maybe you've seen & nbsp; I'm 206 plus & nbsp; I installed the rear stops of & nbsp; & nbsp; in the link
08.05.2020 16:50 # 20
mehmet6667
[Quote = 206206] o & nbsp; When & nbsp; will be & nbsp; change the rear stops :)
maybe you've seen & nbsp; I'm 206 plus & nbsp; I installed the rear stops of & nbsp; & nbsp; on the link
ooo very good bye.
Page : / 2
