Installing a 407 blow off
08.05.2020 14:10 # 1
First of all hello to all friends, I joined the forum today. Peugeot 407 Excutive var blow off I think. Is there any damage to engine or turbo especially for sound?
08.05.2020 14:10 # 2
it would be better if you open the same ball to introduce yourself
I know that blow off does not cause any harm, they say that it extends the motor life accordingly.
The cost is between 600-700 TL for original hks. validity feln dhıl. you get something beautiful
08.05.2020 14:10 # 3
I am using the forum new, so I do not know the details, of course I need to open a separate meeting topic. Greetings, thanks for the info.
08.05.2020 14:10 # 4
H-a-d-i
Blow off is said to relieve the turbo. I did not hear the harm. of course you need a good workmanship.
08.05.2020 14:10 # 5
coyote26
As a result of my long research on blow off and turbo, I think that Blow off will cause some damage to the turbo ... It can make the turbo heal over time because the pressure in the turbo is out ... We received a very nice sound in 307 with 140 hp with 1.6 hdi + superchips software but over time The car started to throw off the oil from the turbo ... I don't talk about it in general but I think it might hurt ... Keep the quality of the blow off connection hoses at the highest level. but blow super is running ....
08.05.2020 14:10 # 6
The diesel engine does not have any pluses, so I think there is no need to handle the mechanics of the car.
08.05.2020 14:10 # 7
Thanks for the information, but a friend of mine told me that blow off was not a diesel, it was powerless that the blow off flour could not open the valve. otherwise it is necessary to intervene in other mechanics of the vehicle in order to increase the pressure from other systems. I would appreciate if you give detailed information and help. Greetings
08.05.2020 14:10 # 8
Coyote hello as far as I understand you have information about this in my car 407 1.6 HDI no superchip can I get the sound if i connect it to an original engine just blow off u under normal conditions brother
08.05.2020 14:10 # 9
I know that even 1.3 multijet is applied, I do not think that there will be a problem in your car as it works in every way. Just the sound you get will not change like impreza: D but at high speeds you will hear a satisfactory choke :) Mustafa 2010-02-18 16:38:49
08.05.2020 14:10 # 10
Eyup Duygun
I think that in a diesel vehicle, as a friend said, they do not make the connection pipes very smoothly.
08.05.2020 14:10 # 11
hasimayaz
The keys are made with keys. a little troubled, in theory it prolongs the lifetime of the turbo, but timing is important as air return is also provided with the key. The slightest mistake puts the turbo at risk.
hasimayaz 2010-02-18 19:20:20
08.05.2020 14:10 # 12
Eyup Duygun
Saying a key in my respectful manager, long work and small pressures, small turbos :) :)
08.05.2020 14:10 # 13
coyote26
[QUOTE = madboy68] Coyote hello as I understand you have information about this in my car 407 1.6 HDI superchip don't have an original engine just blow off u can get sound if i connect it under normal conditions brother [/ QUOTE]
The pressure of the turbo is sufficient for the blow off to work when it is connected with the normal connection apparatus.
08.05.2020 14:10 # 14
Eyup Duygun
there is no problem in the sound event 1.3 we had a multijet jet, we were not satisfied we used it for 1 year personally, I did not get in touch with me but I didn't regret swich event then I did not regret the chip of my vehicle, I did regret the chip deglde.
08.05.2020 14:10 # 15
berko
It is available on every vehicle with a blow off turbo, but on standard vehicles it just doesn't make a sound. its purpose is to expel the air filled in the turbo when you cut gears and gas. It is a very necessary part for vehicles with modified and enlarged turbo. It will be harmful to the engine as it will make the air exit from the incorrectly installed blow off turbo difficult. If you take the hks blow off and install it with good workmanship, you will prolong the life of the turbo and you will be enchanted by the sound it gives: D
08.05.2020 14:10 # 16
Ismail
I have a question, isn't it impossible to use in vehicles without turbo?
08.05.2020 14:10 # 17
Dude, the information is valuable, but I don't want to eat the car's turbo while I am standing still. Do you know a place that does this job without errors? Is there an address? Also, when I install HKS or directly blow the blowoff, the equipment called blowoff is sold with the important pipe quality or something? If it is sold separately, how do I know the quality of it? Greetings
08.05.2020 14:10 # 18
When he says he has overturned our turbocharger, it decreases the performance or causes oil leakage etc. problems. Or does it break the turbo in the long run?
08.05.2020 14:10 # 19
berko
Don't be afraid, blow off is not properly damaged. Take hks, go to a place that has done this work before and get it done. just to say good place, see the blowoff and say "what do you think?"
berko 2010-02-24 14:07:53
08.05.2020 14:10 # 20
H-a-d-i
I think it's no tampering tool. I think you're bored with the vehicle, you want some change. I think the open air filter and a beautiful exhaust will satisfy you. The pejo is a nice car, but if a setting slides, it will plant a fig tree in its stove.
I don't know blow off diosian Göztepe I know a shop in the industry. he is really a master of these things.
Page : / 2
