Inspection with cracked stop
08.05.2020 21:16 # 1
x571
Inspection time has come. The left rear stop was broken and I glued it. I shot a red movie on it. Does it pass the examination in this way?
The vehicle is lpg li. Has anything changed in the lpg regulation? In the last inspection, they asked for the sealing of the spirals in the LPG pipe. What should be done to avoid such a thing?
08.05.2020 21:16 # 2
serkan066066
it goes through an examination. mine was also upset, no problem
08.05.2020 21:16 # 3
x571
[QUOTE = serkan066066] goes through the examination this way. mine broke it and passed it no problem [/ QUOTE]
I hope it will pass. Has anything changed about the lpg
08.05.2020 21:16 # 4
serkan066066
my car is diesel. I can't say anything about that.
08.05.2020 21:16 # 5
talip206
[QUOTE = x571]
If there is a spiral in LPG, they write a slight defect. It was previously the grave defect changed.
08.05.2020 21:16 # 6
x571
[QUOTE = talip206] [QUOTE = x571]
Do you know if anything has changed other than that? Also, does this crack stop lamp inspection also cause problems?
08.05.2020 21:16 # 7
talip206
There is nothing new in LPG as far as I know. My old taillight was also cracked. talip206 2019-06-28 22:59:34
08.05.2020 21:16 # 8
x571
[QUOTE = talip206] There is nothing new in LPG as far as I know. My old taillight was also cracked, there was no problem on inspection [/ QUOTE]
stop passed as a slight defect. this time we stayed from the plate. they can not be comfortable if they don't get ridiculous every year.
x571 2019-07-01 14:53:03
08.05.2020 21:16 # 9
sozuak
When we bought the vehicle in the last examination, they gave the repetition with severe defect because it was written by the state in the license given to 4 people, I should not write 5 persons or vice versa. I will understand if it affects the safety of the vehicle, but nonsense.
In the previous one, there was a window film on the vehicle because I had not paid attention to the fact that it was darker than the R43 on the windows and they wrote a slight defect.
Nonsense is not over.
They announce that they made their own forced one year, the following year.
08.05.2020 21:16 # 10
umydn
I went to the rainy weather 3 days ago. He left the inspection due to oil leakage in the front brake hoses. In the industry, we removed the front brake hoses and looked at the hoses just got wet. We replaced it with a new one. Inspection work is quite a nuisance. He spends the previous one for you for the same reason, but when it comes to you, he leaves it or leaves it for an examination that is not available. The right to serve is important. The guys are hard at work, but they have to be careful.
08.05.2020 21:16 # 11
x571
[QUOTE = umydn] I went to the examination 3 days ago in rainy weather. He left the inspection due to oil leakage in the front brake hoses. In the industry, we removed the front brake hoses and looked at the hoses just got wet. We replaced it with a new one. Inspection work is quite a nuisance. He spends the previous one for you for the same reason, but when it comes to you, he leaves it or leaves it for an examination that is not available. The right to serve is important. The guys are hard at work, but they have to be careful.
It's not difficult. They do simple visual inspection. Millet looks up to 250 lira for gasket control. Are there any caries on the chassis of the lie, headlight adjustment, brake test, horn is working or something they are passing through
08.05.2020 21:16 # 12
cihanozcelik
I do not understand the man falcon falls out, but how does the man pass?
08.05.2020 21:16 # 13
x571
[QUOTE = cihanozcelik] The man hawk I do not understand is falling out, but how does the man pass? [/ QUOTE]
I don't know him too. This business turned cold. Does the 2002 model car's MTV increase every year? It happened two years ago, they cost me 5oo lira including spiral, heavy defect and sealing. They fired from the plate this year. Let's see what nonsense they're going to hit after 2 years.
