insificient oil pressure (insufficient oil) error
08.05.2020 18:06 # 1
korhy
Good evening, when I searched on the site, I did not find a similar title, so I ask under the new title. My car is a 2005 model peugeot 307 1.4 rx. after use, the lights also flicker when idle after stopping, and sometimes stop and give insificient oil pressure warning during this time. I have been researching for a long time, a few problems like this have fallen to the Internet but only insificient oil pressure warning is coming, that is, neither flickering nor tube or stopping are included as a problem. .2 I showed the master the setback did not give a warning at that moment. I can not say anything from the civilization. I would be very happy if you helped.
08.05.2020 18:06 # 2
ahmed206
insufficient oil pressure. let's help friend peugeot problematic
08.05.2020 18:06 # 3
Serkan
Is your oil filter original? Sub-industry filters can sometimes give this warning.
08.05.2020 18:06 # 4
korhy
I'm not sure exactly, but I'll keep it on her, but she's doing the strange thing while on the tube, but not on the gas ... friends are seriously occupying this problem too much.
08.05.2020 18:06 # 5
mustafa_nalcacioglu
If you ask me about the low oil pressure warning, it is due to the fact that when the car starts to misfire, the engine speed drops naturally, when the speed drops below 800rpm, the oil pump decreases because the oil pump does not supply enough oil to the car and the ecu is giving low oil pressure warning. a lot of thought between the oil lamp a few times before I stop immediately, I think there is no problem with the lubrication in your vehicle. sometimes it can break down the problem is probably caused by the lpg system
