Injector Sound
08.05.2020 16:48 # 1
technodex
Hello Friends 1.4 307 I have injector sound in my car, it makes a break between 2500-3000 cycles then cuts, what is the solution of this. by the cheapest. :)
syg.
08.05.2020 16:48 # 2
vbmaster
carbon clean
08.05.2020 16:48 # 3
turbo27
The cheapest way is to have the injectors in common rail systems, set them in the pump setting service, disassemble the 1.4 hdi's injectors like death "Big & nbsp; this will be reflected in the price, on average 200-350 TL disassembly and adjustment, if there is no problem with the valves ... but firstly, find a service with a bench suitable for the new generation ..
08.05.2020 16:48 # 4
metin
injectors previously cleaned? In such cases, when it is cleaned, there is a gap and it makes a chic sound.
08.05.2020 16:48 # 5
technodex
When I bought it, it sounded like it started to increase gradually, I don't know if such a cleaning was done before.
08.05.2020 16:48 # 6
technodex
Is there a place that you can understand from this job that you can recommend in Izmir?
08.05.2020 16:48 # 7
metin
[QUOTE = technodex] Is there any place that you can recommend this job in Izmir? It would be more appropriate to take a new one as a shortcut solution.
08.05.2020 16:48 # 8
technodex
There is something like this, when the car is idling, when I gas it, I press it until the end of the tachometer where it stops, that no injector sound is coming, everything is normal only when it is on the move, no matter what gear it is when they get up, they say the sound of the injector is 2500-3000 rpm. ,
08.05.2020 16:48 # 9
taskin
If you have a problem with the injectors, the vehicle will not work properly, there is a situation with black smoke, there is a gas-related situation, you can only connect it to the computer and look at the values of the injectors. .
08.05.2020 16:48 # 10
sarp
I agree with the taskin friend, he was doing in my partner, I said I would change the trig in the last care, I changed the sound went, the master said that the old & nbsp; trigerin was attached 1 tooth forward. When I put the new one on, it went out in the voice, my advice is increased. If the timing change time has not come, I think it will be removed by a good master and put it back on.
08.05.2020 16:48 # 11
monur
If the vehicle does not idle, does it on load, it is probably the sound of the pump. Because the pump turns at a speed of 2500 rpm when the vehicle is running. It is useful to look at a pump. Probably, it saves the shortest when the repair kit changes, and it will not cause trouble if high quality diesel oil is used for many years. I wish you had written the km of your vehicle.
08.05.2020 16:48 # 12
technodex
Thanks for the information, Kmsi of the vehicle 140.000 & nbsp;
