Injector replacement
08.05.2020 21:15 # 1
Zulfu
Hi all, I have a 2007 model 307 1.6 hdi 110 hp. We connected it to the computer and the 1st and 3rd Injectors mefta said master. The first injector was 2.6 -3.enjektor and was 4.6. Injectors mefta. Anyway, we went and bought 2 zero injectors and changed them. (we changed ourselves) then we introduced the new injectors n codes to ecu. Everything is ok so far. We made diagnostics again. There is no change in the injectors. 1.injector 2.6. 3. Injector shows 4.6. Why might the problem be caused? "Pistons 1 and 3 don't work normally," said the master. Bisey didn't say. He didn't understand. My question will be to you; is it from a diesel pump? Or else?
It also offers fault codes:
p0483 cooling fan proportion control malfunction.
P1351 idm circuit input failure
P1461 A / C pressure sensor circuit high input
I would be very happy if someone who had happened before or someone who understands the problem, please reply.
Note: timing set. Turbo. All the filters have been changed.
Zulfi 2019-06-01 19:36:01
