Injector or Valve Failure
02.11.2021 17:35 # 1
Elobaron
First of all, hello friends, I bought a 1.4 16 Valve 2007 model 307 last month. As someone who owns a 206 for 4 years before that, there was a problem with my vehicle. The previous Info faulty error was giving me an error. controlled by compressor 4-3 The valve presses up to 210 2-1 leaves it at 90 The master said that the valves are burnt. There is no problem with idling in the gasoline in my vehicle, it is not bad in terms of traction, there is only a little vibration in the engine and there is a slight patter in the exhaust. Injectors came to my mind as far as I know. If it is clogged, it does not send the fuel it wants to the cylinder anyway. They measure the valve test according to the pressure of the incoming fuel, what kind of way should I follow? Could the problem be caused by the injectors?
02.11.2021 21:47 # 2
assaint
Hello
The valve is burned, the engine does not work properly at idle, the traction is low, it explodes, but the circlip may have stuck. Remove spark plugs 1 and 2 and apply a generous amount of WD40 to both cylinders. Install the spark plugs, disable the coil, press the starter for 5 seconds so the car will not start. Leave it like this for 30 minutes, then run it normally. Hope it works.
02.11.2021 22:13 # 3
Elobaron
How do we do this process, sir, frankly, I am looking for a solution other than the valves, it is a very expensive price, there is no fluctuation in the rev counter when idling, there is no problem in the starter, there is no problem in the starter, it reaches a speed of around 170 when driving on a straight road. There is a vibration in the engine and if you listen to the exhaust very closely, there is a small popping. I noticed this problem when I connected it to the computer by chance, but why this compressor test may be low, I am trying to solve it, as you said, if there is a ring sticking, is it solved in this way and we wait 30 minutes after plugging the spark plugs and pressing the starter for 5 seconds, and then we put the coil on and start it, right? Is it useful to throw wurth injection and engine cleaner as an extra?
02.11.2021 23:12 # 4
assaint
Try your luck as follows.
02.11.2021 23:48 # 5
Elobaron
We need to install the coil while operating normally, right? Without the coil it will not work anyway?
03.11.2021 08:15 # 6
assaint
After tightening the WD40 and installing the spark plugs, do not install the coil, in this way, press the starter for 5 seconds and let the WD40 spread everywhere. Then wait for 30 minutes and connect the coil, run the vehicle normally, test it and write the result.
