Injector Cleaning (Jerky Operation)
01.10.2020 14:43 # 1
dfiratd
Hello; The vehicle runs jerky and noisy in gasoline, according to me, the starting time is one click long, one of the master said that the injector may be blocked. When switching to LPG, the shaking and sound stop. Since I just bought the vehicle, I haven't had the chance to look at the spark plugs or injectors yet. I researched some craftsmen said that the injectors of these vehicles cannot be cleaned. I wanted to ask the dear friends here. 1- Could jerky work in gasoline be caused by injectors? 2- Is injector cleaning done in 1999 306 Griffe vehicles? 3- Is there a master acquaintance to do these works that will not upset us in Antalya?
01.10.2020 18:19 # 2
talip206
1. Injector or petrol pump may vibrate, but there is a high probability of injector. 2. It is cleared. If you find injector carburetors in the industry, they disassemble it, install it in the machine and clean it. I even know that bosh carservisler does this job. There is a lion master (difference automotive) in Antalya. There is a youtube channel called repair shop. It looks at the volkswagen group though, but at least gives an idea or directs.
02.10.2020 14:23 # 3
dfiratd
Thanks
02.10.2020 14:53 # 4
ismailkaya
Take 4 new 4 spark plugs Coil and coil cable, oil maintenance, belts, wheel balls front set 4 tires okay don't look back, let it go
02.10.2020 15:36 # 5
dfiratd
[QUOTE = ismailkaya] Take a new 4 pieces of 4 spark plugs Coil and coil cable and oil maintenance, belts, wheel balls front set 4 tires are ok, don't look back [/ QUOTE] İsmail Bey I did oil maintenance, air and oil filters were changed, The tire is zero, the timing has changed, the pressure lining has changed, the front arrangement is in very good condition, the front discs and pads have changed from the best, the battery is reset tomorrow. I made a cost of 450 TL. My problem is jerky working in gasoline, it gets better when I switch to LPG, they have not changed the gasoline filter for a long time, I will change it and try it, I do not know how much the injector will clean, but it really forced the car cartridge if it was cleaned and passed. I dropped from 5th gear to 4th gear. The vehicle cruise does not deviate very well when the brake is pressed, it does not even giggle its lap nose, it has never been an accident. It's perfect if I fix that problem with gas.
02.10.2020 15:37 # 6
dfiratd
By the way, I forgot to mention that tomorrow I think to change the clutch cable myself, the lowest labor cost in Antalya is 150 TL. I'll buy a clutch wire from the supplier industry.
02.10.2020 20:02 # 7
ismailkaya
If it does only with gas, have the injectors and cables checked. Take a good look yourself before you take it to the repair shop, if there is any foam cable
05.10.2020 11:44 # 8
dfiratd
I've never checked the injector cables before. How can I do it?
06.10.2020 15:35 # 9
x571
[QUOTE = dfiratd] Hello; The vehicle runs jerky and noisy in gasoline, one of the master said that the starting time is one click long in my opinion, the injector may be clogged. When switching to LPG, the shaking and sound stop. Since I just bought the vehicle, I haven't had the chance to look at the spark plugs or injectors yet. I researched some craftsmen said that the injectors of these vehicles cannot be cleaned. I wanted to ask the dear friends here. 1- Could jerky work in gasoline be caused by injectors? 2- Is injector cleaning done in 1999 306 Griffe vehicles? 3- Is there a master acquaintance who will do these works that will not upset us in Antalya? Thank you. [/ QUOTE] same problem yes, mine does it in winter. summer properly. I think the injector was 250 TL per piece. change makes more sense in our vehicles. The next year, because the others are broken.
07.10.2020 13:19 # 10
dfiratd
Won't you do an injector cleaning?
