Injector Cleaning
08.05.2020 15:48 # 1
vbmaster
Friends I guess one of the injectors is not working exactly how much money for the 206's or can I disassemble and clean it? He said that the vehicle is damaging carbon clean at 130 thousand.
08.05.2020 15:48 # 2
vbmaster
I looked at the cleaning issues of these injectors, as if they were overcoming us, as if they were putting them in a water or something, wouldn't they be cleaned by spray?
08.05.2020 15:48 # 3
vbmaster
Sir, I said that I will not open a separate topic when it comes to this place. Does this ODIC system of my car have a vehicle 206 Roland Garros 2000 model but does anyone know that I know that it has odbII connection?
08.05.2020 15:48 # 4
vbmaster
having an idea ¿
is not there
08.05.2020 15:48 # 5
turkuaz55
[QUOTE = vbmaster] Friends I guess one of the injectors is not working exactly how many money is the injector kit for 206 s or can I disassemble and clean it? He said that the vehicle is damaging carbon clean at 130 thousand.
injector is not a job we will do .... he said there is a problem with master injectors in my car (there was a misfire problem in the car) then he took out the injectors, he put it on the machine ok then he put it on the car, the car did not work.
However, the problem is that it is a hose going to the turbo, so the long word short injectors are not repaired (not valid for every car).
08.05.2020 15:48 # 6
vbmaster
obaa 2billion, my teacher, are you seriously so expensive? Do I get a carbon clean appointment at the peugeot service now? say what?
08.05.2020 15:48 # 7
turkuaz55
[QUOTE = vbmaster] obaa 2bill what is my teacher seriously yaw are these zigzags so expensive? Do I get a carbon clean appointment at the peugeot service now? say what? [/ QUOTE]
yes exactly i found it in konyada ..... but my car has 2 liters 1.6l but 2 liters is hard .....;
If your problem is in the injector, I say go to a good service ... first tell me your problem ..... go to the industry and clean the injector then you will be like me ...
08.05.2020 15:48 # 8
vbmaster
I'm going on the road, the car suddenly does not eat gas 2 seconds later pat yellow engine lamp injector cleaner threw it passed but it did 7-8 times in 3 months 2 days after it is recovered, the light goes out, usually it was 33 degrees in the rainy weather it was the first time I was surprised :)
08.05.2020 15:48 # 9
turkuaz55
yes the problem is the same in me but the only difference is that I did not have the engine lamp on, but the problem arises when the computer is plugged into the service.
08.05.2020 15:48 # 10
vbmaster
Yaw, this computer is very nervous to connect to the computer, I will take me from the device with ODBII bluetooth, open the laptop from the net. 50 lira want to look at the guy already, 70 lira tool :))
08.05.2020 15:48 # 11
vbmaster
There are even cheaper on ebay if you do not get stuck on customs
08.05.2020 15:48 # 12
F-Eren
get it done clean carbon shook it did not hurt I made you number ten
+ performance
+ I have + fuel economy
I can give an address if you want
08.05.2020 15:48 # 13
ODB-II happens to almost all of them. Normally PP2000 is used in services and it is expensive. Now the Gin version has also come out and there is no discernible difference from its price, but there is as much difference between the device you are talking about and the mountains.
If you want to clean the injector yourself as the last process, the injector is usually deposited and expected inside a glass filled with gasoline.
