Injector Cleaning
08.05.2020 16:48 # 1
cemesk
Hello Friends
2004 model 1.4 hdi, I started having difficulties on departures. Occasionally, there was a problem with the reverse gear, and I thought that the vehicle had a pressure pad at 130,000 because the clutch had started to harden. I went to the master today and made a test drive so that I could make an appointment for the replacement of the pad. He said that the pressure pad is normal, it is the same in the 307s, that if we clear this problem from injectors, it would be 100% correct, I couldn't make any sense. & nbsp; I am very confused what do you think I should do?
08.05.2020 16:48 # 2
cemesk
date
Reviews
08.05.2020 16:48 # 3
senol73
Hi, my teacher told you which master you went in Eskişehir and the injector will be cleaned.
I think it would be fine
08.05.2020 16:48 # 4
cemesk
I am always very pleased with the master I have been to so far, has found a solution to many of my problems. I postponed last summer so we could clean the injectors. now it is back on
08.05.2020 16:48 # 5
senol73
I can say that my master is good too, but it would be nice to get another idea. div>
08.05.2020 16:48 # 6
cemesk
You are right, teacher, it is useful to get ideas from another place. I don't want to touch the injectors much now
08.05.2020 16:48 # 7
mesutay20
I have a late working problem .. I poured injector cleaner but it did not help much .. If you do, I would appreciate if you let me know the result by message. because beim, I did not have a master, I said all injectors.
