Injector adjustment expert advice
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
22.09.2020 16:09 # 1
Erol75
Hello, I own a Peugeot 3008 2010 1.6 hdi Autor6. My car is throwing black smoke. Especially when I press the gas. The Eggr has just changed. The particle filter has just been cleaned. Injectors were revised. There is no indication of malfunction either. With 55 lt, I can only travel 700 km in the city. Left Injector setting left. Is there an Injector you would recommend? And what is the injector adjustment operation fee approximately?
24.09.2020 12:00 # 2
Professor, if the injectors are revised, the settings have been made or the ground may not have been made. Average prices for adjustment and repair vary between 600-2000 TL.
24.09.2020 16:27 # 3
Erol75
Thank you for the answer. I will check the Injectors again. Do you know a good master on the European side?
24.09.2020 17:54 # 4
unfortunately my teacher. You'd better go to a good injector. He will disassemble it at the master and send it to the injector.
