injection pump |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 17:51 | # 1 |
| 08.05.2020 17:51 | # 2 |
gokha_nn |
I think there is a leak from somewhere. Can't pump healthy gas from the warehouse. I think it is necessary to check the pipes of the vehicle. |
| 08.05.2020 17:51 | # 3 |
2005 hdi diesel in me, the same in the rubbish ..
| 08.05.2020 17:51 | # 4 |
Do not have any answers, friends. There is wetness on the edges of one of the valves on the engine, which I think is diesel. can i disassemble it My closest master would be in trouble on the 200 km road.
| 08.05.2020 17:51 | # 5 |
Let me write the answer :) The injector is disassembled with the apparatus called as to unscrew the 2 screws of the injector. The stamp that leaks the exploding air underneath is replaced. It is re-attached after wiping it thoroughly with a cloth. You found an open shop on the eve of my feast, so that I can see it before I set out !! I tried to open it as I understand, even though I did not understand. so he worked for 4 hours, injected the injector .. we found someone else whatever he saved me .. cost 150 rubles. While 30 TL will be finished :) the idiot master has removed one of the screws and forgot the other one. did not push too much. he says he has an institution attached to me. When we do not understand, we become mascara in the hands of such men ...
