injection lamp and water shortage !!
08.05.2020 15:00 # 1
pevo
hello, my car 306 platinum fast injection lamp is on, what is the reason for this? Is there a malfunction or something related to lpg?
08.05.2020 15:00 # 2
pevo
no one to help ???
08.05.2020 15:00 # 3
peugeotefe
How many engines do your vehicle have and only the malfunction lamp is on, etc. If there is any problem, we will definitely try to help if you open the topic.
08.05.2020 15:00 # 4
pevo
vehicle 1.6 engine operation or something is just occasionally switching to gas
Also, water is constantly decreasing, there is no water in the engine but it is not clear where it goes
08.05.2020 15:00 # 5
peugeotefe
It can burn the injection lamp due to gas.
08.05.2020 15:00 # 6
pevo
thanks how much it costs gasket
08.05.2020 15:00 # 7
STALLONE
1) if you are going to check it, check the hoses first 2) you will start and check the recirculation vehicle the gasket leakage rate is very low because if it was something, it would start burning fat but if you don't understand the contamination
08.05.2020 15:00 # 8
ali oncu
Do you have to check it out first? then the gasket may be burned, as he says. in this case it will be reduced. Efe ful knows better
08.05.2020 15:00 # 9
pevo
ok thanks
