Information on the 206 cruise control
08.05.2020 16:54 # 1
Serkan
Friends 2 weeks ago, I had my vehicle fitted with a cruise control, it caught my attention today, when I pressed the horn, the cruise control is disengaged, I tried it at least 20 times, and when I pressed the horn, it turned off, I wonder if the system works like this, or I got com2000 when I was doing the trip computer operation, is there a problem with it? Serco05 2012-07-16 11:10:13
08.05.2020 16:54 # 2
KenBlockJR
For safety reasons, it is normal for the horn to go off
08.05.2020 16:54 # 3
istanbullu_3886
I have never tried, I will try when I leave
08.05.2020 16:54 # 4
serkans_21
I have 206+ plus how do I install the cruise control.
08.05.2020 16:54 # 5
No, what else, horn and CC has nothing to do with. Now I am saying it like this, but do I get the opposite? & Nbsp; "LOL"
It does not happen, it is a disarming of the horn and cc. There is no connection.
08.05.2020 16:54 # 6
MemoTech
It is a very interesting situation, I have never played a horn before the stabilizer is on :) If I do not forget tomorrow, let me look at an experience, but they do not write in the user manuals, but they did not have any information that can be deactivated with the horn. & Nbsp;
My attention The only difference was the following: When I switch to pause with the II Pause button, pressing the II Pause button again does not exit the pause position, ie CC does not activate. It is activated by pressing the set buttons.
08.05.2020 16:54 # 7
[QUOTE = MemoTech] Very interesting situation I have never played the horn before the stabilizer is open :) If I do not forget tomorrow, let's look at an experience, but they do not write in the user manuals, but they did not have information that it can be deactivated with the horn. & Nbsp;
The difference that caught my attention was just that when I switch to pause with the II Pause button, when I press the II Pause button again, the CC does not exit from the pause position, so CC does not activate. It is activated by pressing the set buttons.
My entry. Could you be speeding up? Because when he presses that key again, he fixes it to his previous speed.
08.05.2020 16:54 # 8
MemoTech
Unfortunately, it does not reactivate in any way. Whatever way I deactivate the clutch, brake or pause button, it always activates with the set buttons.
08.05.2020 16:54 # 9
Serkan
My brother Mehmet also deactivates the key on the end of the arm that you mentioned as the pause key and does not switch it back on or even it has 308 of your brother-in-law and it is impossible to fix the speed on the screen. I am sure about the horn, I traveled 200 km yesterday, maybe I tried it 20 times. As soon as I press the horn, I apply light pressure from the circuit, but it does not go off without sounding. "smileys / smiley1.gif" border = "0" alt = "Smile" title = "Smile" />
08.05.2020 16:54 # 10
Serkan
[QUOTE = MemoTech] Unfortunately, it does not reactivate in any way. Whatever way I deactivate the clutch, brake or pause button, it is always reactivated with the set buttons.
08.05.2020 16:54 # 11
MemoTech
It is a blessing for us to be like this rather than at all :)
08.05.2020 16:54 # 12
jack67
[QUOTE = Serco05] Friends 2 weeks ago, I got my car stabilized, today it caught my attention when I pressed the horn, the speed stabilizer goes off, I tried it at least 20 times, and every time I press the horn, it was deactivated, I wonder if the system works, otherwise I bought com2000 when I was doing the trip computer operation There is a problem? [/ QUOTE]
Hi, I have 206 in my model, but I couldn't implement the cruise control. Can I find out from you where and where the cable was pulled, what can I find out?
08.05.2020 16:54 # 13
Serkan
[QUOTE = jack67] [QUOTE = Serco05] Friends 2 weeks ago, I got my speed stabilizer on my car, it caught my attention today, when I press the horn, the speed stabilizer goes off, I tried it at least 20 times, and every time I press the horn, it is deactivated, I wonder if the system is working, otherwise the trip computer operation i got com2000 quit while doing it has a problem with my ten? [/ QUOTE]
Hi, I have 206 in my model, but I couldn't implement the cruise control. Can I find out where and where the cable was pulled, what can I find out? Thanks! We did not pull the cable for it, we just attached the arm and introduced it from pp2000. Of course, 3 masters worked for 5 hours and 15 hours for this introduction process, but we solved it. If it is a model, it is probably 2-wire, so it is necessary to pull cable.
08.05.2020 16:54 # 14
Serkan
By the way, I tried many times again, when the horn is pressed, the cc is deactivated, though I started to see this by taking a plus for myself :)) When the sudden vehicle appears in front of me, my foot goes to the brakes immediately.
08.05.2020 16:54 # 15
sahin_2978
I have friends got 1.6 cıtroen berlingo in 2008, I got a speed stabilizer but & nbsp; & nbsp; software & nbsp; dummied & nbsp; indicators disabled & nbsp; I tried the staying & nbsp; cruise control & nbsp; circuit & nbsp; & nbsp; ot & nbsp; but & nbsp; & nbsp; displays are & nbsp; & nbsp; all & nbsp; & nbsp; Resetting & nbsp; & nbsp;
08.05.2020 16:54 # 16
sahin_2978
help & nbsp; I am waiting
08.05.2020 16:54 # 17
[QUOTE = sahin_2978] friends I have a 2008 1.6 cıtroen berlingo I got a speed stabilizer but & nbsp; & nbsp; software & nbsp; dummied & nbsp; indicators disabled & nbsp; I tried the staying & nbsp; cruise control & nbsp; circuit & nbsp; & nbsp; ot & nbsp; but & nbsp; & nbsp; displays are & nbsp; & nbsp; all & nbsp; & nbsp; Resetting & nbsp; & nbsp; [/ QUOTE]
Doesn't the software work without throwing away?
08.05.2020 16:54 # 18
Serkan
The same happens in gasoline 1.4 206, man, they haven't found a solution yet
08.05.2020 16:54 # 19
sahin_2978
software & nbsp; attigi our & nbsp; displays are & nbsp; Resetting
08.05.2020 16:54 # 20
[QUOTE = sahin_2978] software & nbsp; attigi our & nbsp; displays are & nbsp; resetting [/ QUOTE]
So this has nothing to do with the cruise control. Somehow it doesn't work properly in your new software tool. Is it true?
Page : / 2
