Information from friends who understand the subwoofer?
08.05.2020 18:48 # 1
Barut
Greetings. En-ab1120 fusion brand self-amplifying subwoofers
One of my relatives gave me the subwoofers that came out of the vehicle he bought, he doesn't understand the room.
This machine works, I looked at it but I couldn't find it. How do you think the device is? If it works, is it necessary to get an amphitheater? Thanks in advance.
Red dream 2014-09-23 05:03:15
08.05.2020 18:48 # 2
herry
of course, why not work. The beautiful instrument is on both the amphitheater.
For this device, it will be enough to buy an extra installation cable.
a master who knows how to assemble it.
Wink
herry 2014-09-21 11:59:31
08.05.2020 18:48 # 3
Barut
[QUOTE = herry] works, of course why not. The beautiful instrument is on both the amphitheater.
"Wink"
[/ QUOTE] He said so in his friend that he will disconnect the cables from his vehicle in case he is on his amplifier. All you have to do is assemble it :)
08.05.2020 18:48 # 4
herry
[QUOTE = Red dream] [QUOTE = herry] works, of course why not. The beautiful instrument is on both the amphitheater.
"Wink"
[/ QUOTE] He said so in his friend that he will disconnect the cables from his vehicle in case he is on his amplifier. All you have to do is assemble it:) [/ QUOTE]
so good, then be good
Clap
08.05.2020 18:48 # 5
Barut
[QUOTE = herry] [QUOTE = Red dream] [QUOTE = herry] works, of course why not. The beautiful instrument is on both the amphitheater.
"Wink"
[/ QUOTE] He said so in his friend that he will disconnect the cables from his vehicle in case he is on his amplifier. All you have to do is assemble it:) [/ QUOTE] thanks for your interest, master
"Clap"
08.05.2020 18:48 # 6
Cyrus35
My friend, I can help me in more detail here and write the text under the head of the amp, the amp head amphitheater and the installation work to be accessed to this amp is more infectious and disease. You always want more. If you are going to enter the mid team, you will be able to raise the amp and the amplifier if you write down the answer on the amp and the bottom.
08.05.2020 18:48 # 7
Barut
[QUOTE = Cyrus35] My friend, I can help me in more detail here, write the text under the head of the amp, the amphitheater and the installation work that will be accessed to this amp is more infectious and disease. You always want more. If you are going to enter the mid team and remove the amplifier and the amplifier, I can say the answer if you write the values on the amp and on the sub [/ QUOTE] Hodja, I will connect more than 2 speakers and if necessary, I will get an amp. It is enough to give a nice sound like this.
I'll take the picture off and take a picture.
08.05.2020 18:48 # 8
Cyrus35
I would be glad because I will take the amp, if the amp on the diode is a streo amp, you only get a mono amp, so the bass amp can be attached to the oval ovals and doorpipes in the amp on the press. In this work, you do not have trial and error method, you are hurt a lot .. The end of everyone who starts to let me play thin and give a little bass is the fully equipped version of the vehicle. Thumbs Up so you have to investigate the best you will get and minimize the mistakes and losses by acting with the knowledge of what you have and what you should get, mate. And don't mind! ! Installing the cabin by taking the back pendulum off .....! ! I made that mistake. As I will break it, now I will cut the mdf. The original cut is bouncing in the cabins since it is light and bad material. Not to worry about the quality of the sound Thumbs Down
08.05.2020 18:48 # 9
herry
[QUOTE = Cyrus35] I would be delighted because I will receive the amp, if the amp on the diode is the streo amp, you can only get a mono amp, so the bass amp can be connected to the oval ovals and doorpipes in the amphitheater on the press. In this work, you do not have trial and error method, you are hurt a lot .. The end of everyone who starts to let me play thin and give a little bass is the fully equipped version of the vehicle. Thumbs Up so you have to investigate the best you will get and minimize the mistakes and losses by acting with the knowledge of what you have and what you should get, mate. And don't mind! ! Installing the cabin by taking the back pendulum off .....! ! I made that mistake. As I will break it, now I will cut the mdf. The original cut is bouncing in the cabins since it is light and bad material. Not to worry about the quality of the sound Thumbs Down [/ QUOTE]
Thumbs Up
08.05.2020 18:48 # 10
Barut
I disassembled it, but it doesn't write anything.
When I search for brands and models, foreign sites come out, I don't understand much because I don't have English ...
Fusion is mentioned as the en-ab1120 brand. Red dream 2014-09-23 05:05:17
08.05.2020 18:48 # 11
Barut
actual
08.05.2020 18:48 # 12
yawruaslan
Properties
Max Power Rating 360 Watts
Frequency Repsonse 4OHz - 500Hz
Bass Boost (Variable) 0 / + 18dB 0 / + 18dB
Low Pass Filter (Variable) 40Hz - 250Hz
Tuning Bass Reflex
Woofer Size 12 ”
Fuse 15 Amp
Box Dimensions 520mm x 375mm x 405mm
20 1/2 ”x 14 3/4” x 15 15/16
Maximum Power Rating (Watt) 360
Frequency Response 40Hz-500Hz
Bass Boost 0 / + 18dB
Low Pass Filter 40Hz-250Hz
Tuning Bass Reflex
Woofer size 12
Enclosure Dimensions 520mm x 405mm x 375mm
  • BRAND NEW Fusion Remote Level Control TR-AB1120 12 "Active Enclosure (Box Design) Encounter
  • 12 "Woofer Box With Built-in Amplifier, Wiring Set, Bass Remote Control
  • Box "Wide X 14 3/4" High "/16.25" 11.5 X 23 Mi Deep (Top / Bottom)
  • Green Embroidered Fusion Logo Black Carpet
  • 1 port on the front
  • Singel 12 "Green Encounter Woofer With No Trim Ring (Grid)
  • Amplifier Has Hi / Low Level Inputs
  • Variable Low Pass Filter: 40Hz - 250Hz
  • Variable 18 DB Bass Boost
  • 20 Amp Fuse
  • 360 Watt Maximum Power Scoring
  • 40-500 Hz Frequency Response
  • 5/8 "MDF Case
  • Acoustic Striped
  • Bass Reflex Tuning
  • Preset for Optimum Performance
  • Heavy Load Enclosure Construction
  • Remote Level Control Included
  • Cabling Kit Content: 15 'Red & 5`, Blue Turn-On Wire, 17' Green RCA Cable & Wire Ties Black 10AWG Wire (Power Wire 30 Amp Fuse ATC Fuse Holder)
the yawruasl 2014-09-23 08:45:58
08.05.2020 18:48 # 13
Barut
Baby lion, bless you, thank you very much.
I think the friends who understand now help better
08.05.2020 18:48 # 14
Cyrus35
It does not write rms features, but it is very powerful and it is certain that there is no bass for the amp. so you can use it by adding 2 oval or mid team with peace of mind.
1 set mid
or
1 set oval
I am from oval, you can not get performance from mid team beautiful back. bi piooner new model is 500 wat 100 rms I guess I am writing from the research, if you say that I will buy the oval now, I will load the product code in your picture, I recommend you oval, you will use it with peace of mind
08.05.2020 18:48 # 15
Barut
[QUOTE = Cyrus35] does not write rms features but it is very powerful and it is certain that there is no bass that will exhaust the amp. so you can use it by adding 2 oval or mid team with peace of mind.
1 set mid
or
1 set oval
Well, master, let's do it as you said. If you search and write the ovals that are suitable for you, it is very acceptable :) As far as I understand, there is no need to buy extra amps by the affordable ones. It is enough to get a small voice already :)
08.05.2020 18:48 # 16
Cyrus35
Pioneer TS-A6975S 6 'x 9' inch 500 Watt 3-Way Oval Speaker is the speaker I use in my current car, my brother .. believe it has a great sound clarity and look again, I say again, loud speaker, it is very important to take a look at this place. I believe you will say the same thing to me, I personally bought this product on the recommendation of the hoporlor repairman, I bought it for 50 repairs until the evening, and the man is using it in his own vehicle. I don't buy pioneer sales representative starboard ha premium, so hehe :) net treble bass combination is a perfect speaker You can find it between 120 and 140 TL. the product is too much on the current market;) Verdiginn worth the money. You do not need any other amps, by the way, I am sure that this system will satisfy you in the sound. Thumbs Up
Cyrus35 2014-09-23 22:54:18
08.05.2020 18:48 # 17
Barut
Cyrus35. Thank you very much :) I got rid of this problem thanks to you. I will get the ovals at the first opportunity.
08.05.2020 18:48 # 18
Cyrus35
May Allah be pleased with our sentence, I always ask :)
08.05.2020 18:48 # 19
yawruaslan
I am using the pionerr old series in the back pendulum in 106 right now, the code is not in my mind, I am not sure about it 6985 but I am sure it is an oval column, it gives a nice bass and treble sound. I have it :) now I have hertz 30cm bass with a cabin in the trunk, 2 pioneer columns in front of the mid team, sony, I have a nice tape, it is enough for me already in the car :)
