information display freezing !!! emergency aid.!!!
08.05.2020 16:37 # 1
cenk41
& nbsp; I changed the original tape of my vehicle but the information screen gives the normal right or left door open warning when the door is opened, but when the door is closed, the text freezes when the door closes, freezes on the clock : S something very boring, people are crazy, what can I do please help.
08.05.2020 16:37 # 2
Alicilik
Sir, I do not know if there is a solution for this, but if you replace it with 3 lines of screen, there is no problem.
Or if you press any button, it will return to the old state.
08.05.2020 16:37 # 3
cenk41
What is the 3 line display price, also the 2004 model & nbsp; would it be x-line vehicle? pressing the button only the date appears, the clock is still dull?
08.05.2020 16:37 # 4
cenk41
vehicle 206 1.4 75 hp 2004 model
08.05.2020 16:37 # 5
Alicilik
There is a 2002 model and above, there are ads for sale on the site.
08.05.2020 16:37 # 6
cenk41
Thank you very much for the help.
08.05.2020 16:37 # 7
cenk41
the price is quite expensive, just don't we have the chance to solve it with the apparatus, and also the tape does not work on the control arm?
08.05.2020 16:37 # 8
Alicilik
I don't know if the apparatus has that function. I used a single-screen display with a converter, but there was no change.
You have to ask and learn if there is a solver.
If you get a screen, you can also activate the trip computer. Reviews
08.05.2020 16:37 # 9
cenk41
um, is there a trip computer in my model? what information does it contain?
08.05.2020 16:37 # 10
Alicilik
There is a trip computer but it is off the system.
Try the event in the link below to your priority vehicle. -206-road-computer-com2000-tu-yapm
Then you get 3 lines of screen and you can activate the road computer via PP2000 from any pejo service.
By contacting cherno35, wired the joystick on your tape It can make remote input available.
08.05.2020 16:37 # 11
Alicilik
trip computer;
Road that can be traveled with the current fuel,
Road taken since the trip computer was reset,
Instantaneous fuel consumption rate lt / 100km
Consumption rate since reset
Average since reset speed Reviews
08.05.2020 16:37 # 12
cenk41
Thank you very much for the information you provided. I'll try them on my first Sunday when the weather gets better: D
08.05.2020 16:37 # 13
ibrahim YILDIZAK
There is no need for the connections of the tape to be wrong, so ask. I had the same problem, I corrected the connections, I fixed it. No need to buy Com2000. If you want to use 3 lines instead of one line, that is a different matter.
08.05.2020 16:37 # 14
cenk41
eywallah. Thank you, I was looking at how I can handle it in the simplest way. Let's see the master, master traveler.
08.05.2020 16:37 # 15
ibrahim YILDIZAK
You can go to someone who has a solid set.
08.05.2020 16:37 # 16
burak206
Incidentally, I shared the I SOLVE event: D & nbsp;
& nbsp; I changed my original tape, it was freezing just like you did. disassembled their heads, welded back, plugged in, and the screen is no longer freezing: D & nbsp;
so remove the battery terminals, wait half an hour, plug it back in, the screen disappears: D & nbsp;
08.05.2020 16:37 # 17
cenk41
last Sunday, the job came out this market, I hope I will try everything, I will solve this work: D: D thank you for help
08.05.2020 16:37 # 18
cenk41
burak206 & nbsp; & nbsp; & Nbsp; eywallah : D I removed 1 min. I waited back, I corrected: D cost = "0". It will do my job for now.
08.05.2020 16:37 # 19
burak206
[QUOTE = cenk41] burak206 & nbsp; & nbsp; & Nbsp; eywallah : D I removed 1 min. I waited back, I corrected: D cost = "0". For now, it will do my job.
