Information about the partner
08.05.2020 18:51 # 1
osman cagri kara
Good day everyone, I think to buy pejo partner in the 2000-2003 model range, I am unsure about the engine option, 1.4 gasoline 1.6 and 1.9 2.0 engine options.
in particular, we want to be a model that will not cause problems with less fuel burning.
08.05.2020 18:51 # 2
P206HDi
The 2005 model 2.0 HDi is very economical compared to its counterparts. It burns around 30 cents in the city. 1.9 diesels burn more than 2.0 HDi. So I suggest you look at engines with 1.6 or 2.0 HDi.
08.05.2020 18:51 # 3
osman cagri kara
Thank you very much for the information you provided, but how are the 1.4 gasoline
08.05.2020 18:51 # 4
P206HDi
I used the 1.4 gasoline 206 for a while but I don't know about the 1.4 gasoline partner frankly, but even if you use it with a tube it can burn a lot. Apart from that, it is necessary to investigate whether the engine power is enough. There may be a problem if you are going to carry a load.
