Information about the 206 sound system?
08.05.2020 15:13 # 1
CihanHancerli
Friends, I bought a pionner 400w oval speaker for my 206 car. Actually, if I don't give weight to the bass, it sounds pretty good, but sometimes I want the car to vibrate when I turn the sound on. The vehicle has a pionner 6050ub as a tape recorder. What should I do now, both if I take the bass and if it sounds loud? Should I connect the amp or not? Sırıtma What happens if I connect :) I really have no idea about the sound system :) I would appreciate if you help
08.05.2020 15:13 # 2
tigerland
If you want to feel the bass, you need to make a system jbl 6 channel or xetec 6 channel amp rockford fosgate punch sub. and you can get a mirror like sound with 2 suitable mid set
tigerland 2011-04-01 19:54:10
08.05.2020 15:13 # 3
CihanHancerli
Since I am a student, price is important, do you know what their prices are?
08.05.2020 15:13 # 4
oguzhan29
enter according to student budget see all
08.05.2020 15:13 # 5
tigerland
[QUOTE = CihanHançerli] Since I am a student, price is important, do you know what their prices are? [/ QUOTE]
http://www.hepsiburada.com/liste/kicker-double-paket-sistem-10091/productdetails.aspx?productıd=otelf10091&categoryıd=20027180#gorsel on
Could it be 700 TL in everything, only the assembly remains or you can collect the following system. 470 TL cable assembly 570 TL.
http://www.sahibinden.com/ilan/alisveris-elektronik-arac-elektronigi-xetec-vector-200-4-4-kanal-anfi-2-yil-garantili-42315462/detay ?
tigerland 2011-04-02 11:58:07
08.05.2020 15:13 # 6
Muhammet CAKIR
If you want to buy bass, my brother can not get the bass if it is not mdf. jbl 75.4 amp 2nd hand price is 250 tl in a single side, 170 tlye buckles were bought next to it, if it gets wet in the bass veins :)
08.05.2020 15:13 # 7
Muhammet CAKIR
Player's pıoneer amp's jbl columns pıoneer get wofferda kcker :) how much more beautiful sound can be obtained?
08.05.2020 15:13 # 8
dinoco
[QUOTE = Muhammet ÇAKIR] pıoneer amp of the player jbl columns pıoneer be wofferda kcker :) how much more beautiful sound can be obtained [/ QUOTE]
are discussed :))
08.05.2020 15:13 # 9
Muhammet CAKIR
[QUOTE = dinoco] [QUOTE = Muhammet ÇAKIR] pıoneer of the player jbl columns pıoneer be wofferda kicker :) how much more beautiful sound can be obtained [/ QUOTE]
discuss:)) [/ QUOTE] I can discuss :)
08.05.2020 15:13 # 10
dinoco
When I say discussions, I mean
Every model of each brand has its own intonation.
so it should be designed according to music taste.
Uses hard music-loving kicker bass. It has a hard working frequency.
but a user who doesn't want to hit hard should definitely use a softer bass
In addition, the user who wants to feel the bass should definitely wear 2 or one output mono amps.
4/5 channel stero amplifiers never replace a mono amphitheater.
The manufacturer offers a choice of mono amplifiers.
you will notice the difference when the same bass continues with separate ampli as stero and mono.
Also, if you want a beautiful bass playing, it must be inside the trunk in the box that completes the original liter of that bass. Assemblies such as the target / rear trunk sponge are too old.
and the best performance with the current devices at hand is taken from the bass installed in the trunk in the orig liter.
It is used in reverse / straight and or in values such as 2 * 2 4 * 4 ohms, it is also selected according to the taste of the person and the market is placed. this is what i want to say :)
08.05.2020 15:13 # 11
Muhammet CAKIR
I only mentioned the columns for the mdf, the woffer's tray is supposed to be the original container. It is better to use the original container because the bass is the best in the original container.
08.05.2020 15:13 # 12
dinoco
but there is no need for mdf for the reporters. can be worn in the original sponge. or whatever it is, it will be the most beautiful to your taste. Thumbs Up
08.05.2020 15:13 # 13
hunterakon
Well, I installed my 2011 206 + comftuma sound system, let me give you the price of one by one, I am using bass but now the bolts will be removed from the car trembling: D
JVC brand usb tape
1000w box bass JBL
I did not pierce the pandezot so that its originality does not deteriorate. The ALPINE brand speaker, which is 13cm small but gives strong sound.
KAJİWA brand 1000w amplifier KW-6420 has a cooling fan 4 channels good at good price
But most importantly, the cable will not call it cheap.
If you are in Ankara, I know someone who can help, they can assemble 50 lira that understands this job, they do not open the hole in the vehicle securely, they pass through beautiful places.
08.05.2020 15:13 # 14
CihanHancerli
friends, thank you all for your help. I was sick, I could not enter, I could not answer for him.
friends I have 300 TL, I have to decide accordingly. I am only thinking of the amp bass or mid team.
I said don't do a job without asking you
08.05.2020 15:13 # 15
Muhammet CAKIR
If you buy a bass for 300tly, it would be good :) Jameson has 1600 watts of amphitheater.
08.05.2020 15:13 # 16
CihanHancerli
Do you satisfy dios :))
08.05.2020 15:13 # 17
tigerland
I think the amplifier xetec 4 channels 120-150 TL zero electronic components are the same as JBL.
08.05.2020 15:13 # 18
CihanHancerli
Thanks bro, thank you very much
08.05.2020 15:13 # 19
Muhammet CAKIR
Jameson has 1600 watts of which he is very good at the friend.
08.05.2020 15:13 # 20
dinoco
BOSCMAN 1600 W 4 CHANNEL ANFI AND BLAUPUNKT 30 '' ORIGINAL LITER BASS IN THE BOX IF YOU WANT 300 TL.
