Information About SMEG (Update + Codes)
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 18:47 # 1
Advantan
Pictures are not advertising bought directly from my own site, I want to share all of them in Turkey on the SMEG does not get much information.
How to Update SMEG?
* These Updates are only valid for 208 and 2008 models. To find out which version of your SMEG device is, press and hold the MENU button on the SMEG for 10 seconds. It will write update information on the right side of the screen that comes up. Probably it has a lot of versions of 208 and 3:15 in 2008 with Turkey.
need
  • 4GB or more FAT32 Flash Memory
  • SMEG Update File
Click to access SMEG Update Files
* SMEG Update 3.20.A.R3.rar file (for SMEG devices without navigation)
* If the SMEG + Update 4.1 D.R2.zip file (for Navigation SMEG devices)
Yes, after downloading our appropriate file
123321
We open Winrar and extract the file
2424
We throw the extracted file directly into Flash memory without opening the folder.
555
And it's time for the update process, before we insert our Flash memory into the USB port of our vehicle, we get the car running, whether you drive the car or wait at idle, but the engine must be running.
  • We plug in our USB Memory and start waiting, SMEG will automatically scan the memory (a warning called Media Verification), then you will see your Old update version and the new update version to be replaced. Press yes to start the update.
  • Wait without touching the SMEG Screen at all. New firmware (software) will be started to be installed on the device as below image.
IMAG0756
  • When finished, SMEG will be restarted automatically, and BEWARE here. After the device restarts, the screen asking us to update again will appear, we remove the flash memory before pressing anything, and then we touch No.
  • That's it, SMEG has now been updated.
SMEG Codes;
Press and hold the MENU button to enter the SMEG Codes, keep pressing it when the smeg information section comes up (do not pull your finger at all), the CHEAT CODE section will appear.
BT: In SMEG, Bluetooth is always on. When you enter this code, you can turn it on and off.
BTINFO; It projects the Bluetooth information on the screen.
BTRENAME; You can change the bleutooth name.
BTSTARTER; To reboot when the Bluetooth hardware encounters a malfunction.
FPS: The screen displays the FPS rate.
HWINFO: Displays SMEG Information.
NETINFO: Displays internet information for navili models.
PING: Measures GPS ping for Navili models.
REBOOT: Restarts the SMEG Device.
SPYCLN: Deletes the search part for the Navili model.
SWINFO: Displays software information.
SYSMON: Displays system software codes.
TUNERINFO: Displays radio - TA information.
Note: It is available in other codes. However, I did not share it as it may damage your SMEG device.
Can Navigation Feature Be Added to the SMEG Device?
I haven't found the appropriate UPDATE file for this yet, but as far as I can see from the system tray, there are 3 kinds of SMEGs, one standard only plays (Multimedia screen), the other has both file playback and internet access (SMEG +), and the third one has a navigation + internet system ( SMEG Pro)
I will give you the necessary information after a full research on this, for now
08.05.2020 18:47 # 2
extremetr
What changes will there be with this update?
08.05.2020 18:47 # 3
Eozgur27
I bought allure in 2008 last week, I bought everything with the exception of the park assist. I'm a bit novice to the vehicle. I discover some things as I use them. The vehicle is very beautiful and comfortable. but when i received peugeot 2008 not playing cd i realized it. I uploaded mp3 to usb stick. I looked at whether I can watch the video. does not show videos. doesn't show the photos either. I can only see photos of album covers. Is there a lack of software or I couldn't do it? I researched about Smeg screen, I could not find any information. I would appreciate if you help.
When I look at the system version: smeg 5.1.fr4 says there is more updated
08.05.2020 18:47 # 4
alabur
Does anyone know what changes the updates will make? Also, are there any other new versions out of these versions? Where did we get it? Or where can we follow?
08.05.2020 18:47 # 5
adamic
Hello to everyone,
My SMEG NAvigation and version 3.15.
What are the changes or improvements after updating the version to 3.20?
Also, are the services doing this update?
08.05.2020 18:47 # 6
kimiraikkonen
I updated it to version 3.21, guys. I couldn't see any benefit. My old version was 3.17. What is the situation with you?
08.05.2020 18:47 # 7
DeRyCK
I updated the version from 3.17 to 3.21, but I couldn't see a difference.
08.05.2020 18:47 # 8
Leprek0n
How do we do the theme installation work?
08.05.2020 18:47 # 9
Kaya82
I wonder if your SMEG screen navigation software work has ended. I have another question. SMEG + UPG SOFTWARE 5.1F.R4 is compatible with navigation.
08.05.2020 18:47 # 10
erdalx5
I have smeg 5.1.fr4 software in my car. I can install 3.20 software in my car. I have a lot of differences visually. get it :)) erdalx5 2015-08-31 14:07:56
08.05.2020 18:47 # 11
ttagay
I updated it in the service, I was not satisfied at all.First it showed how many kilometers to go with the road as 110 km, 90 km or 50 km in the city.After the update, this feature disappeared. They said that they could not be loaded. I called the Pejo center and got the same response from them. I will write to the French pejo on Monday. Let's see what result.
08.05.2020 18:47 # 12
Ugur TERZI
Hello friends, in September 2012, I bought it to my spouse before it was launched. The SMEG version of the tool is older than you mentioned. So I had hesitations, but the links given by my friend who had already opened the subject were gratuitous.
I started to investigate today when a friend who bought a new car told me that he could navigate the car screen and access the internet. If you have a positive development knowledge in the time since the issue was opened, can you share it?
08.05.2020 18:47 # 13
Erginaltinel
Hello there. I own the 2015 model 208. Smeg screen version smeg 6.05.e.r6 But I can't run mirrorlink and apple carplay.
Do I need to update? Or is it possible to activate these features from the cheatcode section?
08.05.2020 18:47 # 14
[QUOTE = Erginaltinel] Hello. I own the 2015 model 208. Smeg screen version smeg 6.05.e.r6 But I can't run mirrorlink and apple carplay.
Do I need to update? Or is it possible to activate these features from the cheatcode section? [/ QUOTE]
First of all welcome, in order to get better help;
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
To Open the Subject of Promotion Please;
Click This Link: http://forum.peugeotturkey.com/new_topic_form.asp?FID=22
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your e-mail address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 18:47 # 15
selcuk766
I cannot access the files. Can you update the link again?
08.05.2020 18:47 # 16
turnasuyu
I found updated files related to firmware. (I could not find the map of Turkey) However, I have doubts about compliance. I expect help from experienced friends. 5.4.B.R8 for current firmware Smeg + screen, 3.21.A.R1 for Smeg screen
My car 2015 diesel automatic 2008 allure with navigation
Is my car smeg + or smeg?
Turnasuyu 2016-06-03 17:10:44
08.05.2020 18:47 # 17
eagleq
Hello friends,
2015 model 2008 1.6 e-hdi allure I am an automatic vehicle owner. The screen smeg + 5.2.A.R9 version in my vehicle was installed . Although I could go to the first maintenance level, I updated the latest version to 5.41.B.R4 and went. I had no problems with the service. There is no noticeable change in the version update. I think it is related to security and debugging.
08.05.2020 18:47 # 18
stulek
meraba
2016 Peugeot 208 1.2 Active EAT6 110 I received my S&S vehicle. I did a lot of research on Smeg display, but I couldn't find much satisfactory information. But I found a new update file. If something goes wrong, I think to try it today. Friends who want to benefit can download from the link below.
08.05.2020 18:47 # 19
[QUOTE = stulek] Hello
First of all, welcome to us. thank you for the information. We would appreciate if you share the results here. good forums
08.05.2020 18:47 # 20
stulek
I updated this day. There was no change. I could not use the Mirror Screen feature with a single type of android device. There was no change after the update.
Page : / 3
