Information About Failure Error
08.05.2020 16:34 # 1
hanniball35
Hello Friends, after connecting my 407 1.6 model vehicle to the pp2000 program, the engine was giving the error I made in the photo below. Does anyone know the reason and solution of these errors?
08.05.2020 16:34 # 2
Does it come back when you delete errors?
08.05.2020 16:34 # 3
hanniball35
yes, my teacher is coming again. shortly before i made the cleaning of the integrator, could it be the first mistake.
08.05.2020 16:34 # 4
hanniball35
After cleaning the bidet, the smell of exhaust changed and a sharp smell began to come.
08.05.2020 16:34 # 5
The spark plugs do not feed, I had the malfunction recently. glow plugs have been dismantled, one of them is faulty. When it changed, it didn't make any mistakes again Glow relay was intact .. & nbsp;
08.05.2020 16:34 # 6
hanniball35
Does it look like the spark plug is defective?
08.05.2020 16:34 # 7
it becomes evident when the brother is dismantled. they are trying to connect their robustness to the battery or something .. & nbsp;
08.05.2020 16:34 # 8
cerci07
There is a topic on the site about how to check if you can insert and check the spark plugs
08.05.2020 16:34 # 9
hanniball35
tsk.ler so what is this preheating relay?
08.05.2020 16:34 # 10
cerci07
& nbsp; a similar piece
08.05.2020 16:34 # 11
Or this. The location of the engine's fuse box is there.
08.05.2020 16:34 # 12
hanniball35
I guess there is no possibility to test the preheating roles. First of all we look at the spark plugs.
08.05.2020 16:34 # 13
djchaos
The glow plugs and relay may have failed due to short circuit or ground. Check the glow plugs first, if it is intact, take a look at the relay and make sure that the glow plugs are original. br /> Original Spare Parts
0216 631 10 80
0216 631 18 12
0533 301 88 06
www.peugeotmarket.com
08.05.2020 16:34 # 14
hanniball35
I hope you will try whatever you say thanks to everyone. Although you delete the above error in the picture above, do you have any information, even though I delete the second error in this picture, the error does not go away.
08.05.2020 16:34 # 15
djchaos
they will help you if you contact parts that are not on the site or if you write a track request in the forum.
link for track request
http://forum.peugeotturkey.com/forum_topics.asp?FID= 125 & title = ahin-peugeot-auto-spare-money-san-ve-tic-ltd-ti
