Information about amplifier installation ..
08.05.2020 14:03 # 1
hasimayaz
Friends I have a 2 X 400 Watt Sierra Subwoofer. I am thinking of installing one of these and attaching it to my vehicle. Currently, 206 original sound systems + 2 JVC speakers are attached to my Navitech DV player. Now, I say, let me get 2 channels of amphitheater. How should I do it, especially bridging. What kind of cables should I use? Original cable kits were expensive .. Coaxiel cables if I hit the ends myself ??
08.05.2020 14:03 # 2
Emin
What is this pool problem?
08.05.2020 14:03 # 3
I bought a cable system for a total of 50 pounds, including the brothers .. cables cadence brand did not cause any problems.
08.05.2020 14:03 # 4
hasimayaz
[QUOTE = EmRaH] I bought a cable system for a total of 50 liras. Not 2.5 wires cable .. 3 lira intermediate fuse .. :) .. 50 lira what they want yaw it .. I do it myself :) .. have the machine Çakarı RCA tips
08.05.2020 14:03 # 5
Life is worth it, you're the master of work:) & nbsp;
08.05.2020 14:03 # 6
Emin
AMFI
The amplifier is used to increase sound power and quality. If the car is intended to be connected to the Original radio / tape it must be compatible with this output.
The most important thing to consider when deciding the amplifier power is
Amplifiers two has four or five channel outputs. Considering your needs that may arise in the future, it is useful to choose an amp compatible with some extra features. These extra features include crossover bass and treble adjustment mono output.
Footnote Haşim ayaz
08.05.2020 14:03 # 7
hasimayaz
[QUOTE = Sure] AMFI
Footnote Haşim ayaz
& nbsp;
Do what you know to cheat :)
08.05.2020 14:03 # 8
elenor
& nbsp; First I say easy, & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp;
& nbsp; If you are considering getting stereo amps to set up the sound system, you will need to choose among the models that are suitable for bridging. Here are a few points to consider when connecting the stereo output to the speaker & nbsp; For example, if we assume that the left channel's plus & nbsp; pole is connected to the minus pole of the right channel & nbsp;, the negative side of the left channel is bridged by connecting the plus end of the right channel to the plus pole of the speaker.
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; However, the most important thing to note here is that if the speaker ohmaj value that the amplifier can drive is normally 2 ohms, then the ohmic value that should be on the speaker when the speaker is attached should be twice the size of this value.
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; No need for expensive cables in audio cables You can do it yourself by soldering the audio cables to the jacks if possible with suitable jacks. >
08.05.2020 14:03 # 9
hasimayaz
Dude, after doing some research now, I made a decision like this. I'm going to get one Jameson 840 or Edison 1000A mono bass amp. I have two questions:
& nbsp;
1. There is a RCA output from the tape called Subwoofer and 4 aux RCA outputs (Rear / L, Rear / R, Front / L, Front / R) I think I will extend the subwoofer to the input of this amplifier? I have my Coaxiel Shielded cable in my hand too much RCA Connectors. I will pull the cable for 2.5 battery supply and 1.5 REM. Of course I have my material bag in my interim insurance. How many Amps should I use alone 30 Enough ?? Is this correct?
& nbsp;
2. Both devices have a lot of settings & nbsp; trimpot settings. Do I have to adjust these settings ?? Who should have these settings? & nbsp;
hasimayaz 2009-05-08 23:32:05
08.05.2020 14:03 # 10
Carmania
Haşim brother misunderstanding we are completely patient with your help and feature illustrated narration. But there is also a word for leaving the bread to the baker, I think leave it to the people, I think you will get the sound adjustment, I think you can get over it. sra 1004 series get a better (I have my own car is fine) or jbl has a low model. I don't have the 4 channel model in my mind but it should have 4 * 75 rms values. DIV> I wrote what I know so much from me "Smile"
08.05.2020 14:03 # 11
H-a-d-i
Hashim brother, I would be surprised by the JBL amp. I haven't heard of an electric leak, but Edison is giving a very clear voice. their bass is great. The 1000A model is also pretty good. I recommend the JBL 1201.1 model. I guess about 450-500 TL.
08.05.2020 14:03 # 12
hasimayaz
[QUOTE = hderelli] Hashem brother, I would be surprised by the JBL amp. I haven't heard of an electric leak, but Edison is giving a very clear voice. their bass is great. The 1000A model is also pretty good. I recommend the JBL 1201.1 model. I think around 450-500 TL. I put it at half price .. I'm testing & nbsp;. For now, if I do not see the problem of satisfaction, keep on going. My head swelled alone. I'll open a switch tomorrow. I'll cut it out :)
08.05.2020 14:03 # 13
HakanGokdemir
Ya Haşim what are you going to do after this AGE, it hurts your sound system, it hurts your head yaawww ... "LOL"
08.05.2020 14:03 # 14
hasimayaz
Yaw hakan, let's work, ours .. When he is single, the man is going crazy about what to do at home :) :)
08.05.2020 14:03 # 15
HakanGokdemir
"LOL"
Who will collect & nbsp; house yaaa
08.05.2020 14:03 # 16
H-a-d-i
There was no need to switch. At the back of the main unit, a yellow thin cable is used to connect the motorized antenna. When the tape is closed, the current from the battery is cut off.
08.05.2020 14:03 # 17
hasimayaz
[QUOTE = hderelli] No need to switch. At the back of the main unit, a yellow thin cable is used to connect the motorized antenna. When the tape is turned off, the current from the battery will also be cut off. The car is returning to its original installation.
08.05.2020 14:03 # 18
I turn off from the tape, I do not do swict or something: D: D
08.05.2020 14:03 # 19
H-a-d-i
Well, when I cut the electricity from the switch, I couldn't understand how the sound is still going through the amplifier. By the way, Harward is a magnificent amp. No word for the 808 and 809 models.
08.05.2020 14:03 # 20
Friends bought a new jvc CD player, but where can I get it assembled in Ankara .. I also have a question, I have 206, the original tape is on the vehicle. Does the image of the chest deteriorate a lot when it is removed?
Page : / 2
