Information about 407s
08.05.2020 19:34 # 1
atomik07
Friends, this issue actually concerns almost all vehicles .. It is a little long but if you love your car and at least your money, I would like you to spare 1-2 minutes ...
I live in Isparta ... My vehicle is 2007 executive model.
There was a slight problem with the left front door lock of my vehicle. In time, the door was not closing even though it was closed without any problems and was giving the malfunction. While I was on the long road, I did not put it on the head except that the door warning lamp was on constantly and the parking lot was pressurized and the door was locked.
Another malfunction sounded like a slight jiggle while the vehicle was idling.
The other malfunction had taken water from the sunroof into my car during an intermediate heavy rain.
In the fourth and last breakdown, I told you that the reversing sensor occasionally failed, but only once a month.
I did not care much about the others except for the sunroof malfunction. But I decided to go to the service. I am one of the former hondaists. I am not accustomed to such malfunctions, since almost all parts in the vehicle are not mechanical and sunroof. As I usually have my car repaired in private services, I took it to Isparta Pejo Service in Pejom. I said let me show other malfunctions when I was ready.
He looked at the door. The door is amazing to close. He said that the door lock has failed and needs to be replaced. And he just said that this fault would cost me 180 TL with workmanship.
Then I said that there was a voice in Rolantide. He opened the hood. He said that the aluminum metal mixture in the front timing casing part of the engine had zavazingo at the bottom on the chassis connection and that these feet were broken, it should definitely change. He told me that it would cost me around 220.
Sunroof also said that the rovings and tires on the edge should be changed, which would cost around 30-40.
He said that the reverse sensor malfunction could also be from the brain, and that he had about 500 in him.
So
door 180
Zavazingo 220
Sunroof 30
Brain 500
Total amount around 950.
I asked the master if it was too exorbitant and whether there was any possibility of repair and convenience. It will definitely change, if it is possible to repair it, I will repair 40-50 lira but there is nothing to do. He told me to ask the electrician about the reversing sensor. Thank you too, I returned home ..
About a week later, I took my car to the auto electrician master I knew in Isparta. I asked for reverse gear malfunction. He connected to the computer. He said that his brain was intact only in chassis somewhere. My vehicle is left for about 1 hour. They found the malfunction and repaired it with a price of 10 TL. I said the door failure. They looked at. They said that there was no malfunction in the door lock, only that the lock was not seated properly. They said that he was a body shop 20-30 meters below and he was skilled in such works. It did not take 2 minutes for the iron in the chassis on the right rear door to replace the iron on the driver's door, and the malfunction passed. I thought I took water from the sunroof, would you change the wick old? There is no problem in his suppository. He said that only the pipes that drain the water from the sunroof were blocked, and he blew air with an air hose and opened it.
I said, can you look at the front triger's cover cap with the legs broken? He lifted the vehicle by lift. He dismantled, boiled and sanded with an oxygen source and made it original like factory outlet. I said how much I owe. He said 40 TL is enough.
I had a little headache, but even though I wrote it with the intention of being troubled, do not take every little breakdown to the service right away. I took care of the fault that the service called me 950 ₺ for 50 ₺. There are absolutely skilled people around you in every subject. It is useful to show them first. This is the main purpose of such sites anyway. At least it will be very different to share the problems here, learn the fault and then go to the master and see if there is a fault in my car.
08.05.2020 19:34 # 2
crazysado
Hodja thank you for sharing useful information among our other friends for useful information.
08.05.2020 19:34 # 3
Thanks for the information, it will be useful for many 407 users.
08.05.2020 19:34 # 4
cenk_pl
Health has been a very useful article. Although it seems like there are a lot of expenses while reading the first time, I see you as much as 50 TL at the end of the article.
