indoor lighting hk
08.05.2020 19:44 # 1
Aysinsa
Hello.
I just joined between you and Iskenderun. and I have Pejo 307 1,4 hdi my car is 2004 model. I have a problem with interior lighting since I bought it in my car, although I took it to the electrician, we couldn't figure out why everything seems normal, but uz. The lighting that should be turned on even when it is turned on by the remote control does not turn on when you open the door, but it lights up when I press the button and automatically turns off when you start the car. Do you think there is a solution for this?
08.05.2020 19:44 # 2
xmen
There is an electrician master leaving the pejo service in the center of Antakya. Someone who is competent will help you ... I can tell you if you want ..
08.05.2020 19:44 # 3
Aysinsa
I would like to get the full address.
08.05.2020 19:44 # 4
xmen
I threw PM ...
08.05.2020 19:44 # 5
07 Osman
Have you checked the door switches?
08.05.2020 19:44 # 6
Aysinsa
I did not destroy, you are right, there may be
08.05.2020 19:44 # 7
Aysinsa
thank you. When I arrive in Antakya, I definitely pass.
