Indicator Problem
08.05.2020 16:31 # 1
fatihgg
Friends, there is a problem in the cold days, there is a problem in the press. I run the problem smoothly in the morning. It is the same. Acum is very new, there is angel, there is mtech xenon. But I did not solve it. ?
Your attention tskler ...
08.05.2020 16:31 # 2
yavuz25
[QUOTE = fatihgg] Guys, there is a problem with the press in cold days. I am running smoothly in the morning. No problem. When I go out on the road, it is the same once in a while. Acum is very new, there is angel, there is mtech xenon. 3000 kmsi.Why to leak?
Your interest tskler ... [/ QUOTE]
welcome to the pevgeot family first. "Wink" Can you say the Zenon connection type. How is the chassis getting in the display?
08.05.2020 16:31 # 3
fatihgg
Tskler, this is the second record. I think the issue has been erased. I think it was a problem.
08.05.2020 16:31 # 4
yavuz25
[QUOTE = fatihgg] Tskler, this is the second registration. I think the subject was deleted. I think it was a problem. ]
I can say that there may be a lack of contact with the chassis cable. If it comes from your hand, I would like to see it. In another matter, the zenon electric should definitely not be taken from the headlight electric from the main chain. For the relay, a separate line should be taken from the electric coming from this arm, a relay system should be installed and a separate line should be drawn. "Wink"
08.05.2020 16:31 # 5
fatihgg
let me tell the master what you say this is the best :))
08.05.2020 16:31 # 6
yavuz25
[QUOTE = fatihgg] I'll tell the master what you call it, the best is:)) [/ QUOTE] If
is not at your best, it would be best to tell the electrician. "Smile Tell someone to support the chassis cable with soldering.
08.05.2020 16:31 # 7
fatihgg
"Thumbs & nbsp; all right. do you know about
08.05.2020 16:31 # 8
yavuz25
[QUOTE = fatihgg] "Thumbs & nbsp; Well, do you know about this oil lamp? [/ QUOTE]
We thank you. I forgot about the oil lamp topic. "Big flashes for 1-2 seconds in our vehicle at the first point of ignition. It doesn't light up after that.
08.05.2020 16:31 # 9
yavuz25
check the oil level on the stick.
08.05.2020 16:31 # 10
fatihgg
When I turn on the ignition, I do not burn. The oil pressure switch was short-circuited, my friend normally said that it should always be burned, he said that there may be a problem in the general line, or the indicator also said the lamp failure, a solid master, every wire is different.
08.05.2020 16:31 # 11
yavuz25
[QUOTE = fatihgg]
When I turn on the ignition, I don't have the ignition. The oil pressure switch was short-circuited, my friend said that it should always be like that, it is a general or even a problem. p> [/ QUOTE]
how it should always burn. If so it is wrong. "Wink" you can control the lamp from the indicator. "Wink"
08.05.2020 16:31 # 12
yavuz25
there is no user manual, look at the original way of working.
08.05.2020 16:31 # 13
fatihgg
I do not hurt the contact, it does not work. No problem in other lamps. I am running.
08.05.2020 16:31 # 14
yavuz25
[QUOTE = fatihgg] I do not hurt the contact, it does not work. No problem in other lamps. "Wink"
08.05.2020 16:31 # 15
fatihgg
I have been melting for a long time, we put ten dashboards on the board, there is no problem with the LED on the board.Is anyone knowing a master who can solve this. off off
08.05.2020 16:31 # 16
toga406
Very likely to be from xenon. If it is not quality and competent, xenon headlights draw very powerfully. it is strongly possible
08.05.2020 16:31 # 17
fatihgg
There is no problem with the air in the xenons, but I am looking for a solution to the water oil lamp. Friends are tickling up to the brain.
