indicator lights
08.05.2020 14:57 # 1
desert197
friends I want to make the dial indicators blue. I disassembled the face and looked behind but I couldn't access the bulbs like other vehicles. Need to distribute completely? desert197 2010-11-10 21:27:18
08.05.2020 14:57 # 2
desert197
Friends, nobody opened this indicator. Doesn't anyone know please help ..
08.05.2020 14:57 # 3
only_younus
I guess I saw it on the hardware page of hardware news. They had turned blue. But the bulbs that you said you couldn't see are in a different structure (if they are not in 307 and 206 different formats).
08.05.2020 14:57 # 4
rifatseker
I do not know what your vehicle is, but in general, LEDs are used as backlights on the instrument panels in new vehicles. These are referred to as SMD LEDs, that is, they are quite small leds.
These leds have + and - ends as Anode and Cathode. It is necessary to pay attention to these when assembling. In addition, the voltages and currents that each led operates are different. Generally it is around 3v 20ma. Replacing them requires you to contact someone who understands fine electronic craftsmanship.
You can see the white LEDs in this picture.
08.05.2020 14:57 # 5
Haksen016
Actually fine work, you have to do it.
08.05.2020 14:57 # 6
In my opinion, someone who knows, or you can not gather God enclosure. the albaydemirc 2011-04-22 11:51:48
08.05.2020 14:57 # 7
This is a little bit complicated. Because, as another friend says, the working voltages and currents of each led are different.
For example, you need to get 3.6 or 3.8 volts for the blue led. However, your current circuit probably has around 2 volts. To understand this best, all you have to do is insert one Led with a soldering iron and measure the voltage there with the voltmeter. I have no idea where you will get 3.8 volts, but of course not. But as I said, it's a little complicated.
08.05.2020 14:57 # 8
desert197
Thank you guys for your attention. It was a really complicated job. I had Toyota before, it provided parking bulbs that we know its indicator lighting and I could easily replace it.
08.05.2020 14:57 # 9
mehmet1965
You need to get a dial film to change the color of the dial of the friend.
08.05.2020 14:57 # 10
[QUOTE = mehmet1965] I need to get the dial film to change the color of the dial of the friend, I changed it, I did not need to distribute it completely.
I would be very glad if you explain the application with pictures, brother.
I also have 2000 models 206 Alkış
08.05.2020 14:57 # 11
scorpions_64
The instrument panel's lamp consists of classic 12 volt yellow bulbs. to change it, blue-yellow-red-white etc. you can use transparent led. These leds are 3 volts, but you can use 470 ohms or 1 k resistor on one leg to put it together. Another thing to be careful about here is that no matter how many different colors you install, you will scrape the back of the instrument panel with thinner or thinner-like liquid material. otherwise, the light colors will not change. I made it to my friend's 206 in person. the dashboards were blue. I plan to redraw the dashboard on my own computer and replace it on my computer.
08.05.2020 14:57 # 12
My friend, a foreign site, if I am not mistaken, a friend made shopping here without any problems. if you want a review
respects
08.05.2020 14:57 # 13
scorpions_64
[QUOTE = pugti] my friend, a foreign site, if I am not mistaken, a friend made shopping here without any problems. if you want a review
respects
I know I have reviewed this site before. When I say it is just like this. but there is not much variety, based on my imagination, I plan something according to my head Kahkaha
08.05.2020 14:57 # 14
okay osman. If you do, I am waiting with interest.
respects
08.05.2020 14:57 # 15
toprakk
nothing stays in your hands. take the led strip and paste it to the top of the dial :) you can easily change the color if you are bored :)
08.05.2020 14:57 # 16
Haksen016
hard work.
08.05.2020 14:57 # 17
scorpions_64
[QUOTE = Toprakk] nothing stays in your hands. take the led strip and paste it to the top of the dial :) you can easily change the color if you are bored:) [/ QUOTE]
No brother, it is a job that does not hurry and wants to deal with. Whatever it is, I put the pictures on it after I get the car out of the mod. :)
