Indicator Lighting .. (Analog Air Conditioning)
08.05.2020 20:22 # 1
Peugeot35
This is what you should do if one of the lights on the PEUGEOT 307 air conditioner indicator goes out.
YOU REMOVE THE WING FOUND ON THE RIGHT SIDE AND HOLD THE CLIP IN TWO SCREWS. MORE COMFORTABLE IF YOU RUN FROM THE RIGHT & nbsp;
FULL BACK OF THE AIR CONDITIONER PANEL 2 BOTTLE LIGHT BULB STOPPING YOUR HAND WILL REMOVE THE WHEEL OF THE TEMPERATURE VALVE AS YOU POSSIBLE TO REMOVE THE WHEEL VALVE AND RELEASE A LIGHT WHILE RELAXED. YOU CAN ALSO TAKE THE SAME WITH THE SAME OPERATION IN THE SIDE. com / yEBOR9 "target =" _ blank "rel =" nofollow "> < / font>
NET WHEN THE IMPELLER REMOTE LOOKING IN THE WAY HOLD / TRANSLATE / BUY / CHANGE / REPLACE PROCESSING THIS CLEAN JOB ... & nbsp;
BULB 1 TL I RECEIVED 5 PIECES LET IT STAY IN THE CORNER ..
Reviews
08.05.2020 20:22 # 2
onlycihan
nice sharing thanks. Is there such a method for our 206's or does it have to be completely removed from the front?
08.05.2020 20:22 # 3
[QUOTE = onlycihan] nice share thanks. Is there such a method for our 206's or does it have to be completely removed from the front? [/ QUOTE]
There is enough space in the 307s but we don't have the 206s, unfortunately the subject link & nbsp;
08.05.2020 20:22 # 4
maestro
It worked very hard in time until I removed the air conditioning panel and put it on, it seemed easy.
