Increasing buzzing as the cycle rises, decreasing while descending?
08.05.2020 16:34 # 1
kuantum
As I stepped on the gas in my car, a buzzing rose as if the plane was taking off. this sound comes from deep, but it disturbs me because my old pejo 307 doesn't have that sound. the sound increases as the speed of the vehicle increases, and when I pull my foot out of the gas, it immediately decreases and disappears. It's like the hum of something spinning when I press the gas. I thought of the transmission, but I'm not sure. what can make this sound? the sound comes first ..
my brand-model is in my signature.
quantum 2012-02-13 17 : 58: 09
08.05.2020 16:34 # 2
kuantum
does anyone have an idea about it?
08.05.2020 16:34 # 3
In the private message, you wrote that the sound increases in proportion to the speed of the vehicle. However, if the problem was on the wheel ball, the sound would increase in proportion to the speed, not the speed. If you still think it is from the wheel ball, you can simply test your vehicle by lifting it in the fiber.
08.05.2020 16:34 # 4
kuantum
What if it is not related to the wheel ball?
08.05.2020 16:34 # 5
[QUOTE = quantum] If it is not related to the wheel ball, what could be related to it? [/ QUOTE]
It seems to be difficult to help remotely because you always said that it did not make this sound in the same conditions. Could it be from the transmission? Could it be related to the knock problem you mentioned about the other issue?
08.05.2020 16:34 # 6
kuantum
I suspect solenoids related to gears. but now I look that my solenoids are already new. Now I think I am looking for a problem that can cause knocks and knocks in gear shifts.
08.05.2020 16:34 # 7
kuantum
http://forum.donanimhaber.com/m_41416608/tm. htm
this link has someone who suffers from almost the same situation as mine, and someone wrote a message like this:
" is the transmission gear, which is chronic for our golf, comes from the gearbox shaft ball This type of sound will explode the gearbox after a while if the problem is not resolved. "
what can you say, can the man be right?
08.05.2020 16:34 # 8
okankrgz
What do you call a hum that is in the 3-4-5 gears that are not in the lower gears? or does it do it in every gear?
08.05.2020 16:34 # 9
As if there was a buzzing about automatic transmission ..
08.05.2020 16:34 # 10
kuantum
[QUOTE = okankrgz] What do you think of a hum that is in the 3-4-5 gears that are not in the lower gears? or does it do it in every gear? [/ QUOTE]
is in almost every gear. As the cycle rises, sound is heard. handover thought is decreasing. depends on speed, not speed. i.e. from 2nd gear & nbsp; 3. As the speed rises just before moving to, the hum is getting better, but as soon as I get to 3rd, the sound gradually decreases, but if I throw it into 4th gear, the speed increases again as the speed rises ..
08.05.2020 16:34 # 11
kuantum
This is my biggest problem at the moment, and unfortunately I still couldn't find the solution :(
08.05.2020 16:34 # 12
emin15
Does the sound come out of the car, does it not come off the gas when it stops?
08.05.2020 16:34 # 13
aslan7333
Check the V-belt tensioner ball, the alternator ball, the air-conditioning compressor ball, the steering pump ball, and all the bearings that the engine spins with a belt. I don't know ...
08.05.2020 16:34 # 14
kuantum
[QUOTE = aslan7333] Check the V-belt tensioner ball, the alternator ball, the air conditioning compressor ball, the steering pump ball, all the bearings that the engine rotates with a belt. >
Transmission if I don't know ...
was the problem in the tensioner ball, so yours? did it sound the same way? Did it get better when you installed a new one?
08.05.2020 16:34 # 15
aslan7333
It was a sound that had risen and decreased with the same cycle, after a while it was completely locked, when it did not turn, it smashed the belt, we changed all of it.
08.05.2020 16:34 # 16
kuantum
[QUOTE = aslan7333] Exactly, it was a sound that went up and down with the cycle, after a while it was fully locked, when it did not turn, it smashed it on the belt, we changed all of them. I wonder how many money this product .. Is this? & nbsp; http://www.parcagezegeni.com/V-KAYIS-GERGI-RULMANI-PEUGEOT-307-14-16-16V-ORJ-NO -5751C3, PR-25818.html
if this is, we will also replace the v-belt if the problem is what you say?
quantum 2012-02-16 22:03:05
08.05.2020 16:34 # 17
aslan7333
Yes, the product is correct. It is not necessary to replace the V-belt, if it is worn, it is good to replace it, it is not expensive.
Our guess is, of course, such a simple situation. There is even a device similar to a doctor's stethoscope.
08.05.2020 16:34 # 18
kuantum
as if the buzzing in me was coming from the left front or middle part. this piece is on the right front as far as i know. And also in your vehicle was the buzzing speed increasing and decreasing, or according to the rotational speed of the wheel?
08.05.2020 16:34 # 19
Cmoss06
The same problem I had in me was that the inside of the tensioner roller was oxidized, the master said & nbsp; this problem appears in the winter months.
08.05.2020 16:34 # 20
kuantum
[QUOTE = Cmoss06] The same problem I had with me was that the inside of the tensioner roller was oxidized, the master said, & nbsp; this problem is appearing in the winter months. [/ QUOTE]
Cmoss06 was exactly the same as the problems in the first post of this title? And as I said, was my voice coming from the front left, was it yours? Also, in my car, this voice is making a name in the heat, not in the cold. So there was also summer. It is not a situation that occurs in the winter. Do you still think there is the same problem?
Page : / 2
