Increased fuel after maintenance
08.05.2020 16:11 # 1
illegal_boy
Sa friends..the last week I changed the oil filter of my car's oil filter, the spark plugs ...
Before my maintenance, 50 kilometers with 10 pounds of gas is going to the city, now it is 35 kilometers with 10 pounds of gas. )
I was at the beginning of the maintenance of the vehicle and the bosch double-sparked spark plug came out of it, but when I looked at it from the chassis, my single-sparked spark plug was fit and fitted with a single spark plug ... Could this be the reason for the increase in fuel?
& nbsp; already thanks
Best regards ...
08.05.2020 16:11 # 2
illegal_boy
No arcs who will give information about the subject?
08.05.2020 16:11 # 3
34sea45
Since the maintenance is normal
filters are new, the vehicle will breathe more easily after a while
08.05.2020 16:11 # 4
brutal
I think it is to check the spark plugs .. If there is yellowing in the porcelain part, it has reverse firing.
08.05.2020 16:11 # 5
Either I have 15000 maintenance, I am in the same trouble. & Nbsp;
08.05.2020 16:11 # 6
34sea45
The increase in fuel after maintenance is a normal thing, after a while, you will get old values.
08.05.2020 16:11 # 7
illegal_boy
Thank you, I hope it gets better or it is not overcome
08.05.2020 16:11 # 8
[QUOTE = illegal_boy] Sa friends..the last week I changed the oil filter of my car's oil filter spark plugs ...
Before my maintenance, my car can go to 50 km with 10 lira gas and now it can go 35 km with 10 lira gas. 2,42 fixed place)
I was at the beginning of the vehicle during the maintenance and the bosch double-spark plug sparked out of it, but when I looked at it from the chassis, my single-spark plug was fit and the single-nail spark plug was installed ... Could this be the reason for the increase in fuel? > & nbsp; Thanks for your attention already!
Best regards ...
When you go to the masters, it is a waste of time to search for "which spark plug provides the best performance for your car". look for them and from the vehicle's chassis number and install the standard spark plug. Because they claim they know the best.
I don't believe in every master. Investigate thoroughly. Indicate that your vehicle is LPG and investigate which spark plug your vehicle will get the best performance based on horsepower.
ÖR: http://www.bosch-automotive-catalog.com/public/catalog/products;jsessionid=XPNBl5CWODWOI lgRedirect = true
My vehicle 206 1.6 8V LPG
The spark plug most suitable for my research BOSCH Spark plug, Platinum-Ir CNG / LPG gas (FR 6 KI 332 S) 0 242 240 653
< br>
08.05.2020 16:11 # 9
naturally increases when the air filter is cleaned, it will make a difference if you are using series with fuel performance. & nbsp;
08.05.2020 16:11 # 10
sifremi unuttum
Fuel increase after maintenance is not normal. Fuel drops after I do maintenance.
08.05.2020 16:11 # 11
illegal_boy
I am a hard user of truth ... but it is still excessive fuel increase ... besides this, after looking at the chassis, a brand spark plug other than a single nail bosch was added to the vehicle
08.05.2020 16:11 # 12
metin
you may need to recalibrate the lpg settings when the filters change, throttle etc. change. You may need to do a check in the lpg system, not in your vehicle.
08.05.2020 16:11 # 13
I agree with the text, I think, after the maintenance, the gas settings of the vehicle should be reconsidered because many friends around me make the gas settings periodically because the settings are said to be affected by everything.
