incomprehensible heat problem
08.05.2020 17:13 # 1
efsanemurat
slm friends I have a problem, I do not know if it is small or big or not, in summer, when my vehicle climbed uphill when there were 4 people, the temperature was 110, sometimes even red. and the stop is burning together but the car is not overheating I asked that the burning of the oil lamp was said to be due to the fact that the oil filter was not original because there was no shortage in oil, but I could not give the temperature to my customer.
08.05.2020 17:13 # 2
Burak
it was the same in my car & nbsp; http://www.youtube.com/watch? v = klvqwbwmdag & nbsp; If you watch the video here, the oil lamp temperature lamp was blinking together, when I pulled my foot from the gas, the oil was missing, I suspect the oil filter, but it improved when the oil deficiency disappeared.
08.05.2020 17:13 # 3
efsanemurat
actual
08.05.2020 17:13 # 4
efsanemurat
I do not think that the oil is missing, it has already started after the oil change, it shows the oil in the bar, but the indicator sometimes shows the minimum, sometimes the maximum is attached according to the head :)
08.05.2020 17:13 # 5
Burak
Show the oil filter to be original then show it
08.05.2020 17:13 # 6
xMEGANx
Look at it by hitting the front of your car with water. sometimes dust, mud, dirt can overheat.
08.05.2020 17:13 # 7
Typical thermostat problem. Have you ever looked at it?
The decrease in temperature to the 70s has nothing to do with the bear. Ideally, if the outside air requires -20 degrees, the car's engine should not fall down from the degree to which the thermostat opens when the engine is heated. This is one of the aims of the existence of a thermostat. To keep the vehicle's temperature above a certain degree. Optimum values can only be achieved above this temperature.
koliva 2012-12-24 09:09:47
08.05.2020 17:13 # 8
efsanemurat
Thanks for the answers, but there was no one who said something clearer, where should I start?
08.05.2020 17:13 # 9
sezar206
If you want to change the thermostat bi. maybe it is the cottage on it. Install a winter thermostat and try one.
08.05.2020 17:13 # 10
soldiermertefe
Change the oil and oil filter of your car urgently. The vehicle is telling you, by burning the lamp just because my oil is left (if your oil level is good, it may have lost its feature.) If you look at the room, you can see the room & nbsp; 3000-4000 & nbsp; Change your overheating so you can be comfortable. & nbsp;
08.05.2020 17:13 # 11
efsanemurat
Friends, I wonder if there is a temperature sensor on this thermostat, or is the temperature sensor another place?
08.05.2020 17:13 # 12
efsanemurat
actual
08.05.2020 17:13 # 13
[QUOTE = myth] friends I wonder if there is a temperature sensor on this thermostat, or is the temperature sensor another place [/ QUOTE]
Where is the thermostat? Is it a thermostat box?
08.05.2020 17:13 # 14
efsanemurat
So when I buy a thermostat, it is given together with the temperature sensor. If I don't have a single piece, the temperature sensor distinction
08.05.2020 17:13 # 15
[QUOTE = legendemurat]
ie when I buy a thermostat, it is given together with the temperature sensor. If you don't have a single piece, the temperature sensor distinction
Of course it is a separate piece. When you receive the thermostat you only get the thermostat "LOL"
koliva 2012-12-25 21:57:11
08.05.2020 17:13 # 16
sezar206
The thermostat and the thermostat are sold separately. The sender is outside and the thermostat is inside the hose.
08.05.2020 17:13 # 17
efsanemurat
:)) ok koliva brother how do i handle my problem i start from thermostat you read the subject what do you think i should do for solution
08.05.2020 17:13 # 18
:)) ok koliva brother how do i handle my problem i start from thermostat you read the subject what do you think i should do for the solution
I wrote. You can ask if there is a place you don't understand.
08.05.2020 17:13 # 19
fexzi
I had a similar problem when it was in normal course, it was 100-110 degrees, oil and water, although all the mechanical maintenance was complete, the battery on it was only the battery that came out of the factory in 2004, after measuring the battery and changing the situation, the situation has improved, I would have a look at your battery.
08.05.2020 17:13 # 20
efsanemurat
Well, the battery has not expired yet, let me tell you that in summer, the temperature gauge was playing too much, when the car was shaking or sometimes it was ramping when it was normal, the movement was suddenly falling to 90 again, but it was instant, that is, the needle was playing.
Page : / 2
