In the morning my car is shaking |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:05 | # 1 |
| 08.05.2020 15:05 | # 2 |
After running my friend, give a gas at 1000 - 1500 rpm for 20 seconds when idle. Let's see if it gets better.
| 08.05.2020 15:05 | # 3 |
Diesel car makes a little more than gasoline, it is normal that the factory can put oil on the ground, the problem will be reduced with a good oil and high quality diesel oil.
| 08.05.2020 15:05 | # 4 |
metin |
is shaking from the cold (:
| 08.05.2020 15:05 | # 5 |
alaaddin |
As the weather is cold, the first time I start it, as Titriyo herry says, you will see a little heat car, it will not vibrate :))
| 08.05.2020 15:05 | # 6 |
There were past issues, maybe the motor is shaking as his ears are worn. look at the spark plugs.
