In LPG, the vehicle is overwhelmed
08.05.2020 17:50 # 1
blacke4gle
Hello friends,
About 2 weeks ago, I bought a 50 lira gas in the oil office, which is beyond Ankara's surpass. I used about 150 kilometers. After my vehicle has exceeded 150 kilometers, 4 thousand tilting clogging occurs, as if the gas is exhausted, while the quarter tank has gas, it also works smoothly when I want to go somewhere by car and start it again. When I gas the car it stops suddenly: / They pressed my air? My cunt came, I could not solve it. I have been using the car for about 1 year. There is no problem with gas: /
08.05.2020 17:50 # 2
blacke4gle
Whatever kind of dirt came, he turns the car into fool :) I did not move today.
08.05.2020 17:50 # 3
dukenukem82
Shouting downhill if something iniver remains. Clean the injectors.
08.05.2020 17:50 # 4
Aziz
I heard a process like this.
When the vehicle is idle, I keep it at 3000 rpm and switch from gas to gasoline to gas 6-7 times. give it a try :)
08.05.2020 17:50 # 5
demir306
Make the night 6-7 times, then the injectors will burn, the problem will disappear
What would my teacher be?
08.05.2020 17:50 # 6
Aziz
[QUOTE = demir306] 6-7 times night & nbsp; then the injectors burn, the problem disappears anyway. & Nbsp;
/ QUOTE]
I do not think that it will be a very rare situation even if you say that I personally have done this 15 times on 1 road. > Aziz 2013-08-02 13:17:10
08.05.2020 17:50 # 7
blacke4gle
Today I went on the road for 50 kilometers of gas, and there was nothing in the traction of the car. At the end of 50 kilometers, I stopped the engine. Before 5-10 minutes passed, I started the car again. worked on gas, switched to gas, gave the gas without moving the car, the cycle fell directly to 0, stopped. I returned the same road in the evening, I used 50 kilometers, I stopped once on the road myself, nothing happened. I pulled the car into the garage, stopped it, started it again, came back to it, 1 minute later, I loaded the last gas. At 4000 rpm, he did not cut or endure until the end: D oil office was on the black list for me once more, I bought gas once again, the car went from the oil office a few kilometers, but for the third time I would go and get gas from the oil office :) I hope not :)
08.05.2020 17:50 # 8
Bunyamin.Kar
Do not be surprised by the shell or opet, do not upset both yourself and your car so that I can make 5-10 kr profit,
08.05.2020 17:50 # 9
blacke4gle
Never ask, gas is over, trouble is worry, it's all over. I bought my car from the shell gas, no problem, no problem, 15-20 km less, go smoothly: D
