in-headlight misting
08.05.2020 15:25 # 1
kadir emre
Hello friends, there is misting on the right headlight of my vehicle and it never passes. Have you ever met something like this before?
Note: do not try to see or change the headlight Sırıtma
08.05.2020 15:25 # 2
yusuf206
I hope there is a friend who has tried: D: D: D
08.05.2020 15:25 # 3
mdincer34
I had read it in frum, if I don't remember it wrong, I think it had happened to a friend who had to disassemble and siliconize it while assembling the parts.
08.05.2020 15:25 # 4
F-Eren
[QUOTE = mdincer34] I had read in the frum, if I don't remember wrong, I guess it had happened to a friend who had to disassemble and siliconize the parts while mounting [[QUOTE]
this is the general solution, good isolation
08.05.2020 15:25 # 5
ose
If your car is 206, this link will help you
08.05.2020 15:25 # 6
murat deniz
The only solution is isolation, as F-Ren said. transparent silicone will solve the whole problem.
08.05.2020 15:25 # 7
boranaydogmus
At first, open the back cover of the headlight so that the mists can pass through and let the car stand for half an hour with the headlights on or apply heat to the headlight. Then mist passes but dirt may remain. The only solution to this is to disassemble and clean and travel around with a good silicone.
08.05.2020 15:25 # 8
it is only good if it is to be insulated, but it may be in an invisible crack in the headlight. I say check it thoroughly.
respects
08.05.2020 15:25 # 9
lkr_yldz
As the most healthy friends say, clean the headlight completely, clean it well, and then there are quality silicones that are water-resistant (you can find a wide variety in the building markets) and you need to take them from them very well and isolate them.
08.05.2020 15:25 # 10
hhuzun
air is getting from the gasket .. After cleaning, a good silicone
