in fuel - rim or tire?
08.05.2020 15:24 # 1
cesva25
friends now i have a question .... feast;
As we know, the thick tire burns the car with a lot of fuel, but this is certain ... so does the wheel fit the car too ??
For example, the rim is 16 rims, but does it make it very light like a servant or tire it ??
No problem when 175 or 185 tires are put on the 14 inch rim ...
No problem when 185 is put on a 15 inch rim ..
If we choose a 16 light rim and put 185 or 195 on it, will the fuel change?
I am waiting for your comments ...
08.05.2020 15:24 # 2
yusuf206
I think every option other than the original affects the fuel ....
08.05.2020 15:24 # 3
GokhaN
the rim increases fuel, albeit very little at normal rpm. It lowers traction.
If used at high speed, the increase in fuel rate will be around 10-25 kr this time.
08.05.2020 15:24 # 4
MemoTech
As the base expands, friction to the ground is high and fuel is increasing. Rolling resistance is high and performance is decreasing. The sheet metal wheels that come on it are definitely heavier (if not a very special one) than the other wheels you will install and tire the vehicle a little.
I know from my own vehicle :))
When I switched from 14 "sheet rim to 15" GTI rim (195-50-15), I observed loss of performance and fuel increase in the vehicle.
But it is much safer than 175-65-14.
08.05.2020 15:24 # 5
Eyup Duygun
Every gr you will throw from the walking of the vehicle. If you need to summarize it, it means that it will be more than 1.5kg on the car.
08.05.2020 15:24 # 6
As long as the tire cap has not been replaced, you will not have any serious loss from loss. However, since the widening of the tire increases the deflection, of course, the fuel increases. but it also increases with safety. the choice is yours. but 185 55 15 (206 GTI original scale) in 206, 195 55 15 (306GTI original scale) in 306 is ideal.
This time you get a lot of blows in both the team and the inside of the vehicle as the wheel becomes bigger. comfort decreases well. after a while, you become a pester
For example, at the moment, I remove the tires of my vehicle 185 65 14 and pass it to 195 55 15. exact equals as cap. there is only the difference in width. At this point, not much will change. but the safety will increase much more ...
08.05.2020 15:24 # 7
cesva25
OuchOuchOuch hımmmmmmm ...
