in-box fitr for diesel vehicle
08.05.2020 18:26 # 1
I have 206+ diesel vehicles.It is available in the chip application.I have had to open a topic because I could not find the exact answer if I think the k & n in-box filter for my car can not find the exact answer.I am waiting for your help.
08.05.2020 18:26 # 2
hsnsnl
all kinds of increases and benefits.
08.05.2020 18:26 # 3
furkanyakar
There is no benefit other than sound ... I am claiming that even +1 hp does not matter. I investigated these issues ... because of the sound, but it feels like it's going.
08.05.2020 18:26 # 4
What is the significance of the sound in the diesel vehicle :)) I was having a little more comfort in the car.
08.05.2020 18:26 # 5
barishrocker
I always wondered about this. Does the sound of the diesel improve?
08.05.2020 18:26 # 6
Alicilik
1.6 112 hdi 308 at KN tried neither sound nor performance air mercury.
08.05.2020 18:26 # 7
herry
the box filter does not make noise, friends, I could not see the contribution of the performance. in-box filter is a product made in the same size as fit to the original fabricated filter box of your vehicle. Generally, in-box filters do not wear for performance, but people who want to prevent dust from getting dirt on the engine. The reason is that it has a structure that can filter air more intensely, permeates plenty of air, and at the same time, it has a better filtering structure compared to standard factory filters (dust and dirt), it is very assertive that you can clean it with a spray every 5 thousand km and use it for one million km. They went out with a slogan. (I even throw my open air filter once every 6 months and put it in a new one, I think it is not very healthy to clean it) There are people who say they notice +2 horsepower. There are 2 authorized companies that bring k & n boxers in Istanbul. Even for the gasoline vehicle, if the benefit of the boxer does not matter according to my experience, I think it will not matter at all. Stores in Istanbul, Maslak Industry and Levent Industry are separate companies. You can ask stock and learn. they arrive in 2 months with no order. I bought it.
I hope I helped.
08.05.2020 18:26 # 8
barishrocker
Are there other filters?
08.05.2020 18:26 # 9
herry
next time, I think you are talking about the open air filter. I did not use a diesel car, you do not have any experience in this regard, but I made a search for you now so that I can get information. there are users. they generally did not benefit. In the meantime, a few people said I got a sound, some said that the turbo diesel is not in the car. in my opinion; Since the engine of the diesel is a bit more sensitive engine, it is more healthy to use the original.
08.05.2020 18:26 # 10
hsnsnl
If you use the open air filter, you will be sorry for the turbocharger .. Its box air air filter is good, you can get 10 different normal air filters, you can continue your enjoyment (keep a nice air, you can continue with clean air again). Replacing the silencer and the 2 changes were very good. The air inlet air filter is good for the diesel.
08.05.2020 18:26 # 11
Alper134
a little reliever tool in hot weather but I can not say that it has no effect on performance or fuel .. instead, it makes more sense to change your filter every 5 thousand km, now if you buy good filters at least 200 tl green or something, there is no need for 350 tl ztn.
08.05.2020 18:26 # 12
barishrocker
In other words, we do not participate in diesel, which means that turbo is an important and expensive part ... thank you for the information ... thanks for opening the subject ..
08.05.2020 18:26 # 13
tahasav
I had seen a test on a gasoline vehicle. They used to install filters of various brands in the vehicle and put them into the dyno, and then they did not install any filters and were removed into the dyno, of course, the filter-free vehicle gave higher hp. But when every brand was tried and put into dyno, there was a hp increase.
Of course, this applies to gasoline vehicles and an open air filter.
Keep in mind that what matters in the open air filter is your kit, not the filter. The more cold air the engine gets, the richer your mixture will be. If you put the air filter in front of the engine and put the hot air out of the engine into the mixture, of course you will not see a change.
08.05.2020 18:26 # 14
herry
There are a lot of people in our country who don't know what the open air filter works, but are just looking for what is the best shouting filter, connecting it to the throat butterfly and putting the car into the redline. I think that for me and many of my friends in the forum, it is installed for engine performance before the open filter sound they install in their vehicles. (As long as it is not installed professionally in a place where it can draw the necessary cold air, the open air filter is also a torment for the car, do not be afraid that I will get noise.
08.05.2020 18:26 # 15
Sport air filter gives 2-3-4-5 hp in all pc / psx games Smile
The highest realism of gran turismo and forza, including them, even gives 8-10 hp in vehicles over 400-500 hp. If so many games are not lying. Just by looking at the games, we can say that the hp will increase when we install the correct air filter. LOL
In addition, the sports air filter saves 2-3-4% gasoline in normal use, but it is equivalent to take it with a spoon and grab the gasoline it saves because it spoils the idler after it spoils and gas is pumped for the sound.
dogan106 2014-04-08 16:37:15
08.05.2020 18:26 # 16
After so many comments, instead of buying in-box filter, as you say, I replace it with its original filter every 5000km, at least it will be more economical :)
Thank you very much for all the information.
08.05.2020 18:26 # 17
furkanyakar
[QUOTE = ONE TATTOO]
We request [/ QUOTE]. I have tried and used various kits. With the best kit on a 90 hp engine, you can get the max. power is 2 hp. if you can put this filter out of the car and bring the air to the butterfly in the fastest way :) you realize it while you are using it, car :)) SmileSmileSmile
