In a problem from me :)
08.05.2020 17:42 # 1
reality59
Friends, my 2004 model 307 hdi xr analog air-conditioned vehicle, my problem is that the level 1 and 2 do not work as a stage, 3-4 what could be the reason? :)
08.05.2020 17:42 # 2
fexzi
heating thermal oxidized or there is contactless button on the panel.
08.05.2020 17:42 # 3
Bugra
I can't say anything for the problem, but if you want to look at this topic Wink
08.05.2020 17:42 # 4
reality59
[QUOTE = fexzi] heating thermal oxidized or there is a contactless button on the panel. [/ QUOTE]
this is the air conditioner in me
this unit comes with 3 pieces of cables, there are two cables above and there is one big line at the bottom. Is the insurance of level 1 and 2 different?
08.05.2020 17:42 # 5
reality59
current :)
08.05.2020 17:42 # 6
It belongs to 206 in the photo, but yours is not very different. Clean the area I marked in the photo beautifully. Try it like that. Good luck with.
08.05.2020 17:42 # 7
ondercan
There may be a problem with the clarifier installation and resistance. Usually it happens in the 307s. This is the problem. it will come with its socket.
Good luck with.
08.05.2020 17:42 # 8
reality59
[QUOTE =] It belongs to 206 in the photo, but yours is not much different. Clean the area I marked in the photo beautifully. Try it like that. Good luck with.
I checked here it provides solid transmission, but there is one main line behind it, the problem is I tried to short-circuit the main line and as a result, the 1st and 2nd stage are not working 3rd and 4th stage are working. but how can i solve
08.05.2020 17:42 # 9
reality59
[QUOTE = ondercan] There may be a problem with the clarifier installation and resistance. It usually happens in the 307s. It will be obvious if you disconnect the resistance and look at its socket. It may be a little difficult to disassemble but it is probably your problem. You can see the resistance if you disassemble the glove box and press the cabin air separator button. When you turn it towards and pull it towards you, it will come with its socket.
Good luck with.
I looked at what you said, but I did not see any trouble there, resistances etc. There seems to be no problem but the fan motor transmits solid electricity, but there is a problem with the main line coming from the vehicle to the air conditioner circuit. How can I solve it?
08.05.2020 17:42 # 10
ismailkaya
problem with connection sockets
There was a problem in the same me, I removed the analog stage, checked it, it was fine, I installed it, it didn't work again, then I took it to the service, they said it would normally change completely, I said I have a remedy, 100 TL. they said we'll handle it okay i said handle it tiler i asked where is the problem, they said the cables have a connection socket on the back of the torbid at 307 and they have changed the burned socket there but now it is going to go to the second stage.
08.05.2020 17:42 # 11
ismailkaya
I would say disassemble and check the torpedo connections, but I never disassembled and looked at the connection sockets there
08.05.2020 17:42 # 12
reality59
I understand, thank you, I will look at it in the evening available :)
