In 307, it does not stop from the heat
08.05.2020 16:42 # 1
elsoberano
My friends vehicle 307 digital air conditioner air conditioner is still warm when everything is off (it says off on the screen) it feels hot from the light air vents, the car is warming up, I turn the heater on and off, but even when it is in the closed position, a slight temperature blows, which may be the reason?
08.05.2020 16:42 # 2
Gargi
If you turn on the air conditioner of the vehicle and turn it off by adjusting the temperature to 15, 16 or the temperature you will not be disturbed, your problem is solved.
08.05.2020 16:42 # 3
elsoberano
Thank you for your interest, it was good in winter but when the sun shows its face, the bath becomes "Smile"
08.05.2020 16:42 # 4
Gargi
You're welcome, the first time I bought my car, I had the same problem :)
08.05.2020 16:42 # 5
elsoberano
[QUOTE = Gargi] Thank you, the first time I bought my car, I had the same problem:) [/ QUOTE]
I thought that a different feature is defective, I hope there is no fault. I'll try what you say
08.05.2020 16:42 # 6
technodex
Really interesting ...
08.05.2020 16:42 # 7
elsoberano
[QUOTE = technodex] Really interesting ... [/ QUOTE]
If you really integrate, I couldn't try it today, let's see if it will cook us again & nbsp;
08.05.2020 16:42 # 8
[QUOTE = elsoberano]
If you really integrate, I couldn't try it today. Let's see if it is going to cook again. & Nbsp;
Even if it doesn't cook again temperature will come. The reason for this is that there is a hot water circulation from the heater core in any case. The most robust solution is to cover the ventilation grilles. There is also a button with an arrow on the top right corner of the digital air conditioner. It would be even more helpful if you pressed him.
08.05.2020 16:42 # 9
elsoberano
[QUOTE = koliva] [QUOTE = elsoberano] If you really integrate, I couldn't try it today. Let's see if it will cook us again. The reason for this is that there is a hot water circulation from the heater core in any case. The most robust solution is to cover the ventilation grilles. There is also a button with an arrow on the top right corner of the digital air conditioner. If you press it, it will help you even more. I was wondering if the unit is defective or is there a place I need to shut it off? I will do all the things on the weekend.
08.05.2020 16:42 # 10
& nbsp; I turn off the grills, this time it is not as if the fan is blowing in the direction of the channels and mirrors that give the glass a hot air, but it is obvious when you hold your hand, the windows are closed and it is clear if the weather is hot. I am wondering if it is defective or is there a place I need to close? Then he will not hit the glass yet. There is no fault, so is it for all of us.
koliva 2012-04-12 19:54:50
08.05.2020 16:42 # 11
elsoberano
& nbsp; I turn off the grills, this time it does not seem like the fan is blowing the channels and the mirrors that give hot air to the glass. I wondered if the air conditioner control unit is defective or is there a place I need to shut it off? I will do all the things you do on the weekend, rest mostly on weekdays, my lion.
First, set the air directly from the control panel and then adjust close. Then he will not hit the glass yet. There is no malfunction, so it is all of us.
thank you very much. I am glad that there will be a malfunction and a problem when I first get it & nbsp; If it is no use to be a member of a forum with knowledgeable friends, I would go to the industry and I would have stood if I fell into the hands of this ruthless master.
08.05.2020 16:42 # 12
just307
Hi guys, I was having this problem in my car, but it didn't bother much, but when the weather was very hot the other day, I turned on the air conditioner and from one side the digital air conditioner on one side, cold air was coming from one side, although both of them were 16 degrees in the same way, one side was constantly blowing hot and closed and so on. the same driver's side is always hot, of course, when the engine is hot, what is the problem?
08.05.2020 16:42 # 13
deme
one side of my 307 and one side of my air conditioner blows cold on one side & nbsp; thanks for your attention
08.05.2020 16:42 # 14
metin
There is a button on the top right of the air conditioner. When we press this, it cuts the air inlet from the outside and only circulates the air inside the vehicle. & Nbsp;
button number 3 in the picture. & Nbsp;
If you press this button, the air conditioner cuts off the hot air coming from outside, the air conditioner will not blow out warm air even if it is off.
< / div>
08.05.2020 16:42 # 15
toga406
Turn off all the grills and set the temperature to 18, no problem. Also, let it not get air from outside.
08.05.2020 16:42 # 16
FeverDog
I think it feels warm from the loopholes, and I thought it seems to me. Did I cook in vain:) & nbsp;
08.05.2020 16:42 # 17
dukenukem82
No solution for vehicles without air conditioner :)
08.05.2020 16:42 # 18
There is a glass, teacher, you open it, there is no problem :) we got on slx we know from there :)
08.05.2020 16:42 # 19
dukenukem82
I open it in two mosques, it does not benefit in summer. No money, let's get on the air-conditioned vehicle :)
