In 2005 model 206, 95 octane 97 octane?
08.05.2020 15:00 # 1
I am using the petrol of 2005 model 206 feline, I should buy 95 octane or 97 octane gas. I bought it with 45 liters of gasoline. I bought 45 liters of gas. I went 430 km to the city. I just replaced the car's timing pad, air petrol filters & nbsp; and spark plugs again & nbsp; I am trying to see how long it will go. & nbsp; Can I have a problem with 95 octane gasoline? My vehicle burns 9.55 lt per 100km. so = 400 cents per km
08.05.2020 15:00 # 2
You did not specify, but I think the vehicle will depend on the 1.4. & Nbsp; fuel event usage conditions. it is normal if you enter the traffic in Istanbul or if you are using the revolution ... it comes to about 38 courses. the result is 3.92 pounds of gasoline. you will also maintain the vehicle. oil, oil filter, spark plug, air gasoline filters, throttle engine, manifold etc. will be maintained. the wheels will freeze freely, the brake calipers will work comfortably and the handbrake will not be tight, the pad will not hold the vehicle, and the tire weather will be correct ... I don't think it will happen ... & nbsp; I tried & nbsp; on 98 octane in different vehicles and 100 octane in an intermediate shell. What were the differences ...
cecoli 2010-12-30 10:43:32
08.05.2020 15:00 # 3
C!N
Since your vehicle's engine is 8v, you don't need to use 97 octane, 95 octane is the most suitable fuel for the engine of the gasoline vehicle.
08.05.2020 15:00 # 4
[QUOTE = C! N]
[ / QUOTE] My
& nbsp;
vehicle has 206 feline & nbsp; 1.4 engines. I only knew it as 16v.
08.05.2020 15:00 # 5
[QUOTE = cecoli]
you did not specify, but I think the vehicle depends on the 1.4. & Nbsp; fuel event usage conditions. it is normal if you enter the traffic in Istanbul or if you are using the revolution ... it comes to about 38 courses. the result is 3.92 pounds of gasoline. you will also maintain the vehicle. oil, oil filter, spark plug, air gasoline filters, throttle engine, manifold etc. will be maintained. the wheels will freeze freely, the brake calipers will work comfortably and the handbrake will not be tight, the pad will not hold the vehicle, and the tire weather will be correct ... I don't think it will happen ... & nbsp; I tried & nbsp; on 98 octane in different vehicles and 100 octane in an intermediate shell. There were some differences ...
& nbsp;
Thank you for your comments. I use my car everyday on my way to work & nbsp; I go 5 km and stop. It cannot be said that I have done too much stop. I think I did not force the vehicle too much. I do not exceed 3500 revolutions. & nbsp; generally. & nbsp; Now my perception has gone under the petrol half tank 250 km I went. as it will reach 500 km after the maintenance.
08.05.2020 15:00 # 6
The vehicle should not be 16V. As far as I know, the 1.4 16 valve engine did not come out in the 206s. There are 1.4 16V machines in the 207s ... In fact, what is called octane is the degree of knocking of fuel. As the octane rises, it becomes difficult for the gas to ignite ... But this situation does not occur when the octane is higher. but it requires a stronger firing system ...
08.05.2020 15:00 # 7
C!N
[QUOTE = mstfkrl] [QUOTE = C! N]
Since your vehicle's engine is 8v, you don't need to use 97 octane, 95 octane is the most suitable fuel for the engine of the gasoline vehicle. My vehicle has the engine of 206 feline & nbsp; 1.4. I only knew it as 16v. I remember that the Peugeot 206 series had 5-door hatchback models & nbsp; 1.4 16valve 90PS gasoline engine only in XT equipped versions with 2004-2005 model year. Maybe I might be wrong in the model years, but there are definitely XTs only 1.4 16v engine, the feline model which was produced in the following years is a 5-door hatchback 206, it is the second model after Roland Garros, but the engine is 1.4 8v 75PS.
08.05.2020 15:00 # 8
kizilhakan
Hello, my car is 1.4 automatic, I like about 10-12- kilometers of me as you are in my day, because it is in the city, I can go 200 to 220 km with a gas of 100 TL, I am doing 26 liters of 100 TL, I made all maintenance like you but these vehicles It burns like this. What I said is that even though I try to use it economically, it does not matter in summer and winter. I am doing 280 290 km of fuel. In summer, I am getting 100 TL gasoline. I recommend it to everyone who did not have a problem, let's buy from foreign capital oil companies, let us buy from domestic capital companies, and let our country win.
08.05.2020 15:00 # 9
C!N
http: //forum.peugeotturkey .com / forum_posts.asp? TID = 6380 & amp; title = 95-octane-m-97-octane-m
< DIV> & nbsp;
& nbsp;
08.05.2020 15:00 # 10
[QUOTE = kizilhakan] hello my car is 1.4 automatic like me, i'm driving about 10-12-kilometers a day, it is going to be more in my stagnation, I can go 200 km maximum 200 km with 100 tl gasoline, I make 26 lt spare 100 ll I did the maintenance, but these vehicles are burning like this, what I said, although I try to use it economically, it does not matter in summer and winter. I do not have any trouble to protest their prices a bit, I recommend it to everyone, let us buy from foreign capital oil companies, let us buy from domestic capital companies. [/ QUOTE]
& nbsp;
& nbsp;
> fuel in automatic transmission of course it is increasing more. & nbsp; but & nbsp; while I expect a well-kept 206 to burn 8 liters in the city, I see values in 10 liters previously there were 106 quicksilvers. While there were 14 steel wheel exhaust, air filter, I was not driving the vehicle at less than 6000 rpm, but it still remained at 9 liters.
& nbsp;
Burning less than 8 liters between us 206 do you have?
08.05.2020 15:00 # 11
Is there 206 burning between us less than 8 liters?
& nbsp;
< DIV> no one is there
08.05.2020 15:00 # 12
no for sure :))
08.05.2020 15:00 # 13
GokhaN
not even in factory data, under 8 lt in city. If you say a little bit to the car, I usually watch it on the motorway and watch the city and stop in the city.
08.05.2020 15:00 # 14
Besides, it wasn't going to be a city at that time.
08.05.2020 15:00 # 15
metin
[QUOTE = C! N]
Since the engine of the vehicle is 8v, you don't need to use 97 octane, 95 octane is the most suitable fuel for the engine of the gasoline vehicle.
[ / QUOTE]
& nbsp; my vehicle is 307 1.6 16v but they do not recommend 97 for my vehicle ideal 95 they say wrong do they know?
08.05.2020 15:00 # 16
The bottom one has not read the ongoing articles galıba :))
08.05.2020 15:00 # 17
Yes, friends, I finally took the measurement ..
& nbsp;
The vehicle has been completely tested in the city by stating the engine without warming up. :)
& nbsp;
I filled the warehouse and I went 478 km. Tekrak fulledim bought 45,260 lt gasoline. According to the 13.01.2011 gasoline rate, it kept 178.32 cents from TL 3.94.
& nbsp;
Buddha final values:
at 1 km: 0.0946 lt
at 100 km: 9.46 lt
per km: 0.337 tl
& nbsp;
& nbsp;
08.05.2020 15:00 # 18
values are quite normal ...
I guess the vehicle is 1.4. It is due to the lightness of the ...
08.05.2020 15:00 # 19
deniz_206
Use 95 octane
08.05.2020 15:00 # 20
BUBU
4 tl of gasoline, getting the important gasoline does not matter 95-97 anymore :)
