Improve 207 sound system
08.05.2020 17:41 # 1
umut401
Greetings to all,
I want to improve the sound system of my wife's 2009 model 207 Trendy car. The fabricated RD4 CD radio and torpedo have Mp3 input, also there is a twitter + speaker at the front door and a speaker at the back door. (I say it is because the sound is not like that at all, I looked at the VIN number on the servicebox site, it gave the speaker counts like this.) The sound of the new chassis C4 I use as a company car is perfect compared to this. Of course, there may be many factors such as isolation, sound output, speaker quality, but I think there is an improvement in 207 by adding to the original system.
As a result, can I improve without adding an amplifier or replacing the speakers without changing the original tape? Can I also insert multiple CD changers in the trunk? (Original or other brand)
Thanks in advance for the ideas and help ...
08.05.2020 17:41 # 2
umut401
For example, does this component system work:
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-hoparlor-focal-ifp-207-peugeot-207-16cm-compenant-takimi-90698942/detay
08.05.2020 17:41 # 3
Alicilik
[QUOTE = umut401] Greetings to all,
There is always a higher level in the sound system, there is no end to it
You can take an output to the amp by placing an apparatus in between without changing the original tape. After adding the amplifier, you can amplify the speakers and get a more efficient mix.
I know it can be plugged in because you said there is a USB port. I guess this is one of the pieces that were installed later?
Thanks in advance for the ideas and help ... [/ QUOTE]
In addition, the system you showed in the 2nd message is very great, if you say I give you that money, it would be great for the prevention.
08.05.2020 17:41 # 4
umut401
[QUOTE = Recipient] [QUOTE = hope401] Greetings to all,
Of course, there is no end, but we want clear sound, more of it does not fit us :)
There is no usb in the vehicle, originally there is a box with red and white sockets in the torpedo, to connect the socket of mp3 players ... If I find a multiple changer mounted in the original boot, for example Clarion, this cannot be connected ??
As Sn, I was sick of the Focal component system.
08.05.2020 17:41 # 5
error
unfortunately it is impossible to get a result just by changing the speaker :(
08.05.2020 17:41 # 6
BerkeKarayel
The focalin products in the link you sent are 70 rms, if you plug them in, you will feed them from the tape outlet sockets are holding directly because you have the video on youtube, you need to support them with the mafia like dismounting :)
08.05.2020 17:41 # 7
Bugra
If you want a little advice quality sound and are satisfied enough to say `` eh here '' from the current bass strokes, unplug your tweters and wear them from the same size pionner. you won't believe change.
