I'm having trouble starting up first thing in the morning(HELP) |
| 26.06.2021 15:48 | # 1 |
my vehicle is 1.4 feline. last year I had an LPG kit fitted to the vehicle, it was okay at first but 1-2 At the end of the month, when I press the gas first in the morning, the speed started to decrease, and nowadays, even if I step on the gas, the speed drops and stops. (The vehicle starts at a single start, but) If I can keep the speed above 2 thousand rpm in 2-3 start attempts, then the vehicle gets into normal. I took it to a few places, they said it could be the fuel pump, but after the first start, I don't have a problem when I use the car on gasoline, except for a small amount of jerky operation. Also, when you switch to lpg, there is no problem, it works like clockwork. div> could the problem really be in the pump? If I only buy the pump, if I don't take all the float, will the problem be fixed? I am waiting for your help
| 27.06.2021 22:23 | # 2 |
it's not that at all, first remove the lpg fuse and turn it off from the valve. drive a little bit, let's see what's going on? I experienced exactly what you said in the LPG regulator. |
